94 CX Electrical Problems.
Old Jul 25, 2006 | 12:08 PM
American.Graffiti's Avatar
Default 94 CX Electrical Problems.
I was working on my car and ran into a few electrical problems:
1. Everytime I try to start the car it wont turn over unless its @ random. I hear the main relay click and etc.. but it normally takes a while for the car to start. I checked all the fuses and everything is in good standing.
2. My tail lights stay on. I check all the grounding points I could think of and they still stay on.
3. My EX/SI cluster isnt working @ all except for turn signals and etc.. But when I plug in the stock CX cluster everything works.
Any help would be great,
thanks.
Modified by American.Graffiti at 9:33 PM 7/25/2006
Old Jul 25, 2006 | 12:53 PM
instructor74's Avatar
Default Re: 94 CX Electrical Problems. (American.Graffiti)
when you say tail lights are staying on is it the brake light or the parking light that is staying on? you could try to disconnect the brake light switch and see if they go out
Old Jul 25, 2006 | 01:03 PM
fmrprojects's Avatar
Default Re: 94 CX Electrical Problems. (instructor74)
sounds like you have a bad main relay and its not kcking on the fuel pump to start up the car
Old Jul 25, 2006 | 08:05 PM
Default Re: 94 CX Electrical Problems. (fmrprojects)
I mean it doesnt even want to turn over. I have to turn the key numerous times for it to start.
Old Jul 25, 2006 | 08:08 PM
95DxSi-R2
Guest
Posts: n/a
maybe an ignition switch, like stated above, which lights are staying on in the tail light? do u know how to check wiring? continuity, shorts , power n ground?
Old Jul 25, 2006 | 08:14 PM
O RLY's Avatar
Default Re: 94 CX Electrical Problems. (95DxSi-R2)
Something may have shorted out in the harness. This one time my instument lights wouldn't go out even when the key was out. I pulled every fuse until they went out, and turned out it was my A/C condenser fuse. Not really the same problem, but its quite possible that the wire to your ignition grounded out, and fried the ignition.
Old Jul 25, 2006 | 08:36 PM
Default Re: 94 CX Electrical Problems. (O RLY)
Im going to check that out.
Old Jul 28, 2006 | 06:40 AM
As for the starting problem it turned out to be the ignition wiring. Thanks for the help.
Old Jul 31, 2006 | 12:50 AM
TTT.
Old Jul 31, 2006 | 07:31 AM
O RLY's Avatar
Why is this being bumped? I thought you fixed it.
aLbeRT_LB
15
Nov 10, 2020 12:33 PM
freek21
Jun 27, 2012 05:13 PM
Rhdae86
Jul 30, 2011 07:38 AM
Rhdae86
Jul 29, 2011 05:44 PM
Red Ribbon Army
Jul 24, 2007 05:43 PM
