D16Z6 into 89 HF CRX
Old Jul 25, 2006 | 11:56 AM
joker4096's Avatar
Default D16Z6 into 89 HF CRX
Hi, everyone, I tried searching, but i didn't get any real good info on the swap. What do I need to do this? Should i use the linkage from the z6 or the original one from the hf? Engine mounts? use the stock ones? What about that mpfi conversion thing? It is an HF so i wont need to do that correct? Since the tranny will be a hydro tranny, how can I go about and change the crx to hydro? I heard that Hasport makes an adapter. I couldn't find it unless you buy the b-series mount kit and the adapter comes with it. Please, anyone who has done this swap, I need you advice. all replies are greatly appreciated and thank you all
Old Jul 25, 2006 | 12:17 PM
pinecone's Avatar
Default Re: D16Z6 into 89 HF CRX (joker4096)
Stock mounts work.
If you have a Crx Si tranny you could use it and keep your stock linkages and shifter.
Don't need to do a MPFI conversion, it already is.
Contact Hasport and see what they can do for you.
Old Jul 25, 2006 | 12:52 PM
gp70hs's Avatar
Default Re: D16Z6 into 89 HF CRX (pinecone)
Do you currently have a HF transmissionyou are going to bee removing?
Old Jul 25, 2006 | 03:40 PM
joker4096's Avatar
Default Re: D16Z6 into 89 HF CRX (gp70hs)
yes, i do have the tranny that i will be removing. Is the si tranny the same as in the d16z6?
Old Jul 25, 2006 | 04:13 PM
white90crxhf's Avatar
what are you doing with the hf tranny?
Old Jul 25, 2006 | 04:15 PM
joker4096's Avatar
u want to buy it?
Old Jul 25, 2006 | 04:16 PM
aarontrini85's Avatar
Default Re: D16Z6 into 89 HF CRX (white90crxhf)
call hasport they should sell the adapter by its self and also your map sensor is on your firewall i belive but the voltage scale is the same as the obd1 cars so cut your connector for it and solder it up to a obd1 connector and it should be good to go other then that
i would think your best bet for the tranny is to do a crx si trans rather then trying to do hydro
Old Jul 25, 2006 | 04:40 PM
z691si's Avatar
im attempting the d16z6 swap into a 91 si hatch and im having wiring issues it almost starts i moved the map sensor from the old one to the new one what are the othe two wires on the fire wall old map sensor. also will the old axles work?
Old Jul 25, 2006 | 06:55 PM
pinecone's Avatar
Default Re: (z691si)
I was referring to the crx si tranny, it will bolt to the z6. It is not the same as the z6 tranny. The crx tranny is cable and the z6 is hydro. If it comes with the hydro tranny keep it and see if you can't get the conversion pieces.
Old Jul 25, 2006 | 07:14 PM
joker4096's Avatar
Default Re: (pinecone)
someone said that there is no hydro cable conversion for d-series. I seen that the hasport and innovative kits are with the b-series mounts and the conversion. Thus seeming that they wont work for a d-series. I will use my hf tranny or acquire an a6 tranny and bolt it up. d-series trannies are interchangable i guess.
Old Jul 25, 2006 | 07:38 PM
pinecone's Avatar
Default Re: (joker4096)
You will not want to use the hf tranny with the z6, the power band will be non exsistent.
Get an A6 tranny, that will be your best bet.
Old Jul 25, 2006 | 07:57 PM
joker4096's Avatar
ok, so a6 tranny it is. so the engine wires i wouldn't have to mess with right, just change the connectors for injectors and distributor? The ecu harness will need an obd0-obd1 conversion right?
Old Jul 25, 2006 | 08:07 PM
pinecone's Avatar
You can leave the resistor box and just use OBD0 injectors, won't make any difference unless you plan on turboing the engine later. Yep you will need to change the dizzy wiring. Just go to rywire.com and get their OBD0-OBD1 dizzy wiring harness.
Old Jul 25, 2006 | 10:11 PM
FOMULA91's Avatar
Some good site.
http://hybrid2.honda-perf.org/tech/sohcvtec.html
Old Jul 26, 2006 | 02:06 PM
91SiZ6's Avatar
I've posted the information needed for this swap several times in the last few days. Just scan the board for any other Z6 OBD conversion topic.
Old Jul 27, 2006 | 09:06 AM
joker4096's Avatar
Default Re: (91SiZ6)
I've figured out that the car i have is a dx, DPFI. I know I have to change to MPFi. Rywire has a setup where they can redo the wiring harnesses by sending them a z6 harness and a dx harness so the z6 engine will just plug right up. I might do that
Old Jul 27, 2006 | 03:03 PM
pinecone's Avatar
That is the easiest way. May cost a lil more, but it gives you the peace of mind that atleast the wiring will work right, lol.
Old Jul 27, 2006 | 03:25 PM
91SiZ6's Avatar
RyWire rucking focks!
Old Jul 27, 2006 | 06:07 PM
joker4096's Avatar
i dont mind spending the money to have a perfect swap done, Anyone know where I can get an a6 tranny?
Old Jul 27, 2006 | 08:44 PM
dcteg's Avatar
man i had a nice d16z6 got so ****** perterbed at the car that i just ssold the ****** motor and car never got it runnin but i just used my stock motor mounts and shift linkage...no probs at all then again it had a d16a6 in it before hand
koolme88
23
Oct 6, 2011 12:46 PM
slammedz6ef
Nov 24, 2008 05:23 PM
hfcrx88
Dec 10, 2007 12:30 AM
Mr. Giggles
Mar 6, 2006 01:58 AM
88crx Osaka
May 18, 2003 10:11 AM
