Taking Badges Off My Car, Help
Old Jul 25, 2006 | 11:26 AM
Revolemilbus's Avatar
Default Taking Badges Off My Car, Help
Just took the civic badges off the back of my hatch for a cleaner look, anyone have any tips on how to get that damn glue off without taking off the clear coat?
Old Jul 25, 2006 | 11:50 AM
y-49's Avatar
there is some stuff made just for the glue. but i forget what it is called. u should be able to find it at any parts store
Old Jul 25, 2006 | 11:52 AM
TeamRedline89Hatch's Avatar
Default Re: (yellow rex)
isnt it "goo-be-gone" or "goo-off"?
Old Jul 25, 2006 | 11:57 AM
1990si's Avatar
use some strong *** fishing line and work it behind the badge untill in comes off. Then hit up autozone or walmart and use some goo gone to get rid of the gunk. Then wax that area. You wont even be able to tell it was there.
Old Jul 25, 2006 | 12:02 PM
La EF-8's Avatar
Default Re: Taking Badges Off My Car, Help (Revolemilbus)
Goo gone is what you are looking for. IMO i think that you should leave the badges on, but to each is own
Old Jul 25, 2006 | 01:52 PM
doublethink's Avatar
Default Re: Taking Badges Off My Car, Help (La EF-8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La EF-8 &raquo;</TD></TR><TR><TD CLASS="quote">Goo gone is what you are looking for. IMO i think that you should leave the badges on, but to each is own</TD></TR></TABLE>
orange colored liquid in a clear bottle, sold at home depot and other fine hardware stores.
one thing, once you get all the glue off, just hit it with water and clean rag, it is a turpintine although very mild if the sun beats down on it for a while it might change the color of the paint a bit.
also, the front emblem has two holes in the hood to align it. if you remove the H you will need to fill those hoels with bondo and repaint the front part of the hood.
so be careful if you didnt realize that was needed.
Old Jul 25, 2006 | 02:58 PM
saaron34's Avatar
Default Re: Taking Badges Off My Car, Help (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">
so be careful if you didnt realize that was needed.</TD></TR></TABLE>
is this not true of the rear emblems? Either of them?
Old Jul 25, 2006 | 10:51 PM
Default Re: Taking Badges Off My Car, Help (saaron34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saaron34 &raquo;</TD></TR><TR><TD CLASS="quote">is this not true of the rear emblems? Either of them?</TD></TR></TABLE>
the rear ones are stickers. so no. its cool to lose them if you like.
Old Jul 26, 2006 | 11:18 AM
saaron34's Avatar
hmm good to know, thanks.
makes it that much easier when I finally repaint.
related question: as far as bondo goes for filling the hood holes, will it crack over time? Never used bondo, but I've heard that bondo jobs will crack and crumble. Is this only true of larger areas and not small emblem holes? Example, I've also got a few door dings that I'd like to take care of - is bondo a good way to go?
Old Aug 1, 2006 | 03:20 PM
saaron34's Avatar
haha, I didn't realize you own all CRX's...I popped the emblem of the back of my hatch and there were holes. I haven't cleaned all the glue off the HONDA emblem to see if there are holes yet (yes there was that much glue on there) but there are definately two holes holding the H emblem on a hatchback.
just fyi!
Old Aug 1, 2006 | 03:38 PM
djphonics's Avatar
Make sure you don't mix up Goo-Gone with Goof-Off. Goo-Gone is an orange oil based cleaner and won't hurt your pain. Goof-Off is some NASTY solvent action and will definitely expletive your clearcoat.
Old Aug 1, 2006 | 06:51 PM
saaron34's Avatar
Default Re: Taking Badges Off My Car, Help (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote"> Goof-Off is some NASTY solvent action and will definitely expletive your clearcoat.</TD></TR></TABLE>
which is funny because they are RIGHT next to each other on the shelf at walmart.
I got Goo Gone in the gel form in a spray bottle. you pay a little more, but it seemed like it would be less mess. Its just a little thicker.
crxsir23
Welding / Fabrication
15
Feb 26, 2008 08:26 PM
nickEM2slo
Honda Civic (2001 - 2005)
26
Sep 5, 2007 05:54 PM
.doeboyfresh.
Honda S2000
13
Jul 19, 2005 03:41 PM
rdaggett
Jul 9, 2004 06:24 PM
slammedcivic22
12
Feb 11, 2004 02:04 PM
