97 accord se timing belt question
Old Jul 25, 2006 | 09:29 AM
intezn's Avatar
Default 97 accord se timing belt question
I am about to replace my timing belt on my 97 V4 Accord SE.
What should I replace other than the timing belt and the water pump??
I found these on ebay, will this kit be suitable? It's $144 + shipping, good deal?
Should I order and replace the TIMING BELT AND BALANCE BELT TENSIONERS as well?
PART LIST
14400-PT0-004 TIMING BELT
13405-PT0-004 BALANCE BELT
91233-PT0-003 BAL SHAFT SEAL
06923-P0A-306 BALANCE SHAFT SEAL RETAINER
15114-PT0-003 OIL DRIVE GEAR SEAL
91212-P0A-004 FRONT MAIN (CRANK) SEAL
91213-PT0-003 CAM SEAL
12341-PT0-000 VALVE COVER GASKET
12342-PT0-000 X4 SPARK PLUG TUBE SEALS
19200-P0A-003 WATER PUMP
Old Jul 25, 2006 | 11:03 AM
H8rs get L0st's Avatar
Default Re: 97 accord se timing belt question (intezn)
Its an I4 buddy....
Depends whats in your budget...
Old Jul 26, 2006 | 10:49 AM
intezn's Avatar
Default Re: 97 accord se timing belt question (H8rs get L0st)
budget isn't that important.
the question is do i need to replace the timing belt tensioner and the balance belt tensioner?
Old Jul 26, 2006 | 11:19 AM
TouringAccord's Avatar
H-T Order of Merit
the tensioners are recommended.
I wouldn't buy that kit unless it's all OEM Honda. For this job, use OEM parts. You don't want something to fail and messup the motor or have to go through the entire process again because something failed.
Old Jul 26, 2006 | 12:26 PM
intezn's Avatar
Default Re: 97 accord se timing belt question (TouringAccord)
all parts are oem from a honda dealer.
and both the tensioners are $47 each.
Old Jul 26, 2006 | 01:14 PM
Ihatecars's Avatar
I just did my timing belt and I changed out the tensioners, spring, seals and the water pump. Why leave any reason to break open the front end again. Once is painful enough.
Old Jul 26, 2006 | 01:18 PM
teamlegacy's Avatar
Default Re: (Ihatecars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ihatecars &raquo;</TD></TR><TR><TD CLASS="quote">I just did my timing belt and I changed out the tensioners, spring, seals and the water pump. Why leave any reason to break open the front end again. Once is painful enough.</TD></TR></TABLE>
Not the front end, the left side of the engine.
Anyhoo, I'd make sure you replaced all the seals you could. They can be a P.I.T.A. but they are notorious for leaking and busting out causing a huuuuuge headache not to mention a nice mess.
chandlorexia
Oct 12, 2012 06:40 AM
chandlorexia
Engine Management and Tuning
Oct 11, 2012 10:44 AM
The-Kid
Feb 8, 2008 03:47 PM
shepworldwide
Acura TL, RL & ZDX
Aug 15, 2006 07:37 AM
gamblezhang
Mar 26, 2006 08:06 AM
