90 climate control into 88 crx
Old Jul 25, 2006 | 09:13 AM
B-serious's Avatar
Default 90 climate control into 88 crx
is there any way i can put a 90 crx climate control into my 88 crx. is it plug and play or modification?
Old Jul 25, 2006 | 09:45 AM
B-serious's Avatar
Default Re: 90 climate control into 88 crx (B-serious)
88 crx
91 crx
Modified by B-serious at 11:42 AM 7/25/2006
Old Jul 25, 2006 | 10:23 AM
EL Vap133's Avatar
Why would they be different?
Old Jul 25, 2006 | 11:37 AM
B-serious's Avatar
Default Re: 90 climate control into 88 crx (EL Vap133)
so there noT?
Old Jul 25, 2006 | 11:44 AM
Zaakro's Avatar
ummm one is cable driven and the other is electronic
Old Jul 25, 2006 | 11:45 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-serious &raquo;</TD></TR><TR><TD CLASS="quote">so there noT?</TD></TR></TABLE>
When I first saw your post you only had the 88 crx climate control pics.
Now that I see all the pics, the other climate control looks to be from a Civic or a non USDM CRX. Therefore it is different and you cannot use it.
Old Jul 25, 2006 | 11:55 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
the other climate control looks to be from a Civic or a non USDM CRX. Therefore it is different and you cannot use it. </TD></TR></TABLE>
While it won't work for your particular application,
It is good for parts..
{I had one just like that and I used it to rebuild my old controller..}
The heater control **** and the aluminum stem it mounts on
will also work if that piece breaks in your old unit..
You can salvage the A/C switch for a climate control that did not
have A/C from the factory..
Old Jul 25, 2006 | 12:02 PM
user 72830283's Avatar
edit: nm the non-button control is non-crx after all!
Old Jul 25, 2006 | 12:09 PM
EL Vap133's Avatar
Default Re: 90 climate control into 88 crx (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
Ahhh, here is the man that knows his stuff! Phil to the rescue!
Old Jul 25, 2006 | 12:55 PM
mcabrera's Avatar
thats definitely a clean climate control unit tho... where'd you scoop that from?
Old Jul 25, 2006 | 01:09 PM
Default Re: (mcabrera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcabrera &raquo;</TD></TR><TR><TD CLASS="quote">thats definitely a clean climate control unit tho... where'd you scoop that from?</TD></TR></TABLE>
yea usually they look like they've just come back from war in iraq or some ****...i've only had 2 decent non-cracked climate control to date...and i've had 5 crx's heh
Old Jul 26, 2006 | 08:55 AM
Zaakro's Avatar
Default Re: (pr3d)
I believe that one is on Ebay right now
jdm.norcal
Northern California (Sales)
Feb 18, 2009 08:22 AM
SiMateoAko
Jan 23, 2006 04:31 PM
01h22lude
Sep 24, 2004 06:29 PM
Robb
18
Dec 19, 2003 11:38 AM
miahmouse
Mar 7, 2003 01:13 PM
