I NEED HELP FAST.
Old Jul 25, 2006 | 08:47 AM
racingcrx's Avatar
Default I NEED HELP FAST.
i can't seem to get the axle out of the transmission. and i can't get the axle nut off either. i tried the impact gun. i used a ball joint splitter to separate the axle from the tranny but its stick and won't come out. i need help. give me any other way to take one or the other out PLEASE. thank you
Old Jul 25, 2006 | 08:48 AM
youtouchmytralala's Avatar
Default Re: I NEED HELP FAST. (racingcrx)
cut the bolt off, and keep trying on the transmission side. it will come, you just gotta keep turning the axle and prying, a quick jab seems to work best.
Old Jul 25, 2006 | 08:59 AM
gp70hs's Avatar
You need to get a handheld grinder with a cutoff wheel. You'll have to shave the nut off on one side, to almost the threads on the axle. It should stress relief the nut, to where you can turn it with a socket and a 2' piece of pipe.
To get the axle out, you need to put a large screwdriver between the inner half shaft where it is adjacent to the transmission and put some pressure on it, to pop the half shaft loose. It uses a lock ring that requires a little force to compress, as you pry the shaft loose.
Old Jul 25, 2006 | 09:48 AM
racingcrx's Avatar
sorry to mention it is a d-series motor
Old Jul 25, 2006 | 10:08 AM
psycho.chicken's Avatar
Default Re: (racingcrx)
we had to use a tourch to heat the nut up first...
we stuck a crow bar between the wheel studs.. a 1 inch thick crowbar.. bent to 45 degrees when we finally got the nut off...
We used a craftsman breaker bar and a 6 foor pipe... and 450 lbs (both of us jumping on it...)
it broke free... and bend teh breaker bar and the crow bar...
it will com eoff...
just heat it up for about 5 minutes...
Old Jul 25, 2006 | 10:14 AM
racingcrx's Avatar
THANK YOU.
Old Jul 25, 2006 | 12:01 PM
y-49's Avatar
yeah i used a breaker bar and abouut 4 ft of pipe and umped on it a little. and mine broke lose
Old Jul 25, 2006 | 12:06 PM
JJ's civic's Avatar
Default Re: (yellow rex)
i broke a breaker bar and never suceed just took the hub with the axles
Old Jul 25, 2006 | 05:06 PM
y-49's Avatar
yeah i broke a breaker bar also. but it was a snap on. so i got a new one and i got mine to break lose then
Old Jul 25, 2006 | 09:14 PM
JJ's civic's Avatar
yea i got one from autozone and it has the same warrenty so i bought another one
wasanissanFL
Honda Fit
Mar 8, 2012 06:51 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
huepowered
Mar 27, 2006 12:33 PM
ill phil
May 15, 2003 06:27 PM
