zc dohc or zc sohc
My engine started to burn oil not long ago and its transmission is starting to give me some trouble in 3rd gear.... it is a d16a6 sohc. ps it has 200000 + miles on it
I would like to ask your guys your opinion on what should i do. Because I am planning to add a turbo or a supercharger later on it. So i am looking on the best base to get the most power with the less $ later on. And i dont have the $ for a b series engine.
1st choice : should i just rebuilt this Sohc and its transmission.
2nd : should i swap it with a zc Dohc with transmission
3rd should i swap it with a jdm d16a6? which i figure its the zc sohc.
My plan is to get the best for the $ and that is stays reliable. But you cant always ask to much in this world. Plans are plans. They arent always followed.
rebuild the A6 with 10:1 compression and some head work to rev to 8k, and better cam. Would be a fun little car to drive. Or build it 8.5:1 compression to get it ready for boost.
A6 is identical to the SOHC ZC don't waste your money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda »</TD></TR><TR><TD CLASS="quote">How much power do you want and what is the purpose of the car?</TD></TR></TABLE>
Its my daily driver that is why i want it to be a little reliable.
Also i dont want to make it the fastest thing around. Just enough whp...i guess around 200whp.
The engine must just be something upgradable if ever i want to modify something on it.
Also when i go and drag the car i would like to be able to beat other cars then untuned civics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si »</TD></TR><TR><TD CLASS="quote">sohc zc motors have different cams than the a6 (better ones on the zc)</TD></TR></TABLE>
yeah my dad EF has a sohc zc on it...it feels a little faster...duno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si »</TD></TR><TR><TD CLASS="quote">if u wanna stay relaible, stay na d</TD></TR></TABLE>
With a turbo. If i boost less... the car will be more relaible then at the boost limit...no?
JaHnAbOi
10
May 21, 2006 06:29 PM
