RC310 or RC270 injectors?
Old Jul 25, 2006 | 02:08 AM
jdmB18CT-R's Avatar
Default RC310 or RC270 injectors?
What injector sizes would you ITR owners suggest for a N/A jdmB18C-R?
I daily drive my car and it's a weekend warrior....
I have a 97jdmITR swap in my EK9
jdm 98 ITR header
TODA spec A2 camshafts, cam gears, titanium retainers and dual valve springs
MSD SCI+ box, distributor, wires and external coil
(soon to be replaced with MSD Billet distributor)
Phearable P28 reprogrammed ECU
Carbon intake from password jdm
AEM fuel rail
B&M FPR and gauge
JDM PCT pistons (CTR)
Mugen 2 layer gasket
Unorthodox unerdrive crankshaft pulley
NGK iridium spark plugs
THANKS IN ADVANCE
Old Jul 25, 2006 | 02:11 AM
NorthernXposure's Avatar
Default Re: RC310 or RC270 injectors? (jdmB18CT-R)
270 should be fine...
Old Jul 25, 2006 | 04:49 AM
ITRnorway's Avatar
i got a good deal on a set of 440, but they would work fine with hondata s300
Old Jul 25, 2006 | 05:09 AM
Reid's Avatar
Global Moderator
Until you get a tunable computer, I wouldn't bother with changing the injectors. Is the current ECU tuned for stock injectors?
Old Jul 25, 2006 | 05:22 AM
jdmB18CT-R's Avatar
Default Re: RC310 or RC270 injectors? (Reid)
No not for stock. I told phearable that I was using RC310, I'm still running my stock injectors.
Old Jul 25, 2006 | 06:34 AM
ProjektR's Avatar
how about OBD2 H22A injectors. Pretty cheap and 290cc. Keep it all HONDA!!
Old Jul 25, 2006 | 07:05 AM
Padawan's Avatar
Darth ModerVader
Default Re: RC310 or RC270 injectors? (ProjektR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektR &raquo;</TD></TR><TR><TD CLASS="quote">how about OBD2 H22A injectors. Pretty cheap and 290cc. </TD></TR></TABLE>
A good suggestion, and as Reid alluded to, I would definitely upgrade to a tunable ECU setup.
Old Jul 25, 2006 | 08:35 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmB18CT-R &raquo;</TD></TR><TR><TD CLASS="quote">No not for stock. I told phearable that I was using RC310, I'm still running my stock injectors.</TD></TR></TABLE>
.....just get the 310's. although, for myself i'd go with 550's.
Old Jul 25, 2006 | 08:36 AM
scB20teg's Avatar
Default Re: RC310 or RC270 injectors? (Padawan)
If you ever build your motor you could max out those 310cc injectors, so I'd go bigger, at least 370-440cc injectors.
Old Jul 25, 2006 | 08:56 AM
ChicagoMike's Avatar
Default Re: RC310 or RC270 injectors? (scB20teg)
Im running RC440's
My tuner loves them, it gives him more flexability.
Old Jul 25, 2006 | 11:50 AM
jdmB18CT-R's Avatar
Thank for all the replies everyone , but isn't the jdmITR injectors between 220-270?
Old Jul 25, 2006 | 12:01 PM
realis9's Avatar
what is the down side of running too big injectors? Bad gas mileage? would it put too much stress on the fuel pump?
Old Jul 25, 2006 | 12:31 PM
scB20teg's Avatar
Default Re: RC310 or RC270 injectors? (realis9)
440cc injectors wouldn't be too big at all, tune it well and you will get great gas mileage, there will be no extra stress on the fuel pump.
Old Jul 25, 2006 | 12:37 PM
white rocket's Avatar
I opted for the 310's on a stock motor w/ bolt-ons. Will see how well they work next week after the tune
Old Jul 25, 2006 | 01:32 PM
88 rex's Avatar
Default Re: RC310 or RC270 injectors? (white rocket)
To the OP, I would just get the 310's unless you plan on get something to tune the car with. If phearable set it up for 310's then that's what I'd use. However, if you do plan on tuning then something bigger wouldn't hurt you.
For my own personal inquisition, would 370's be suitable on a stock block/head? I'm thinking a good header/exhaust, intake, and good fuel management could reach something close to 190 at the wheels. Would the 370's suffice or be completely overkill? Not trying to hijack, just thought I'd keep my questions of the same topic in this topic.
Old Jul 25, 2006 | 01:42 PM
jdmB18CT-R's Avatar
Let me know how things work out
Old Jul 25, 2006 | 01:43 PM
jdmB18CT-R's Avatar
As far as fuel pump, Im running a Holley 195LPH. Will RC310 or anything bigger be suitable for that intank pump?
Old Jul 25, 2006 | 02:33 PM
scB20teg's Avatar
Yeah your fine.
Old Jul 25, 2006 | 06:51 PM
jdmB18CT-R's Avatar
Lightning motorsports has a really good deal on the RC injectors. Should I stick with the RC310? Im in the process of making an order. Any last suggestions, I just don't want to regret?
Old Jul 25, 2006 | 08:26 PM
Black R's Avatar
25 Year Member
just get the largest saturated injectors available.
550cc or 750cc
Old Jul 25, 2006 | 08:37 PM
itr1244's Avatar
Default Re: (Black R)
yeah. i got 310 cc on mine.. i should have went bigger.
and i just built my n/a motor.. m22xx + ctr pistons + 4.9 FD. hmm
Old Jul 25, 2006 | 10:12 PM
mtber's Avatar
RC310 injectors should be fine up to around 220whp.
That would be my pick for your setup
Btw, you might want to consider getting your car tuned once you go with a larger injector, or you may want to atleast order a basemap eprom chip.
Old Jul 26, 2006 | 01:38 AM
ITRnorway's Avatar
well, i dont want to recomend AFperformance if you want the injectors fast. i has been over 2 months since i payed for them but i have not recived them
Old Jul 26, 2006 | 04:59 AM
totsie7944's Avatar
get the 310's it gives you alot more playing room if you ever get bigger cams and build up the motor more....I am getting ready to sell my rc 310s off my R in about 2 weeks ifyou wanna hold out. It could save you some money.
Old Jul 26, 2006 | 05:51 AM
jdmB18CT-R's Avatar
Default Re: (CRXnorway)
thanks for the info
