P28
I picked up a P28 ECU and got a conversion harness for my Y5 motor and hooked it all up. I'm throwing a CEL and the car bogs a lot and idles like crap. You guys have any suggestions as to me possibly playing with the timing a little to keep the motor running nice? Thanks!
The CEL isn't on for the hell of it...
[FAQ] ECU thread. Codes, wiring pinouts and more. New and Improved Ecu thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">The CEL isn't on for the hell of it...
[FAQ] ECU thread. Codes, wiring pinouts and more. New and Improved Ecu thread</TD></TR></TABLE>
lol
lol
Okay thanks. I pulled a code 41 which looks like primary o2 sensor heater. It's because my secondary o2 sensor isn't threaded into my header (Wires are too short to reach the hole) I will run my P2N ECU until I get a chance to solder new wires on the o2 sensor. Thank you so much for your help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gworthyunit »</TD></TR><TR><TD CLASS="quote">Okay thanks. I pulled a code 41 which looks like primary o2 sensor heater. It's because my secondary o2 sensor isn't threaded into my header (Wires are too short to reach the hole) I will run my P2N ECU until I get a chance to solder new wires on the o2 sensor. Thank you so much for your help!</TD></TR></TABLE>
The P28 looks for a 2ndary O2 sensor? Didn't know that...because my EJ1's only got one sensor, and a P28...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I maybe wrong here but i think the HX motor uses a 5 wire o2 while the P28 looks for a 4 wire. Thats the reason why your throwing that code, you have to convert. </TD></TR></TABLE>
I'm leaning in this direction too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I maybe wrong here but i think the HX motor looks for a 5 wire o2 while the P28 looks for a 4 wire. Thats the reason why your throwing that code, you have to convert. </TD></TR></TABLE>
Word, I didn't think of that - though I've heard about it...
at op: you shouldn't need to get a diff O2 sensor, there's "how-to's" around if u search (the life of cars isn't restricted to honda-tech), I think I've seen 'em b4
BlueShadow
12
Jan 4, 2005 11:30 PM
Combustion Contraption
May 30, 2004 11:03 AM
