trailer lights
Old Jul 24, 2006 | 08:35 PM
sony224422's Avatar
Default trailer lights
how would i go about hooking up trailer lights to a 96 lx?
Old Jul 25, 2006 | 08:15 AM
sony224422's Avatar
Default Re: trailer lights (sony224422)
anyone.. i just need the connector to hook up to it so i can have the trailer lights. I need left and right turn signal, brake lights.
Old Jul 25, 2006 | 10:21 AM
georgeda's Avatar
Even though a small car like a Honda does not usually tow a trailer, there might be available a plug-in kit that connects to your wiring harness at the back of the car. Try auto parts store where they have hitches and receivers. If it is not available you will have to splice into the wiring at the rear of the car.
Old Jul 26, 2006 | 09:15 PM
sony224422's Avatar
Default Re: trailer lights (georgeda)
thanks, i'll look into that. I'm not really going to tow.. but i like having the option if i really have to
Old Jul 26, 2006 | 09:58 PM
thatasiankidtony's Avatar
hey I don't know if you got it or not, but the 97 accords have a trailer lighting connector in the trunk. Should be in the left tail light..
Black= Ground
Backup light= Green/black
Left Turn Signal= Gree/blue
Right Turn Signal= Green/Yellow
Break Light= Gree/White
Taillight= Red/Black
(all pulled from Accord manual)
Old Jul 27, 2006 | 07:19 AM
ricebike's Avatar
confirmed....
I opened up the access panel in the trunk & whallah!
I saw a trailer light connector sitting inside!
Old Jul 27, 2006 | 11:24 AM
EASY101's Avatar
* B A N N E D *
who says hondas cant tow? lol my brother used to tow a 20ft bow rider with an inboard/outboard. (= heavy *** boat) he had an 88 accord LX-i
Honda's cant tow? yeah right! hahaha
Old Jul 27, 2006 | 03:06 PM
YeuEmMaiMai's Avatar
there is a connection for a trailer on the 5th gen accords I have one on my 94
etrailer.com part # 18336 $26 bux
here is the exact part you need
http://www.etrailer.com/Mercha...e=VWH
Old Jul 28, 2006 | 01:26 PM
sony224422's Avatar
Default Re: trailer lights (YeuEmMaiMai)
thanksss. I probably wouldn't tow.. and if i do its going to be like 500 lbs. I just don't trust my car towing too much seeing its 10 years old and not really meant for towing. I just like having the option
Old Jul 28, 2006 | 02:26 PM
It'll tow up to 1000lbs no problem. Only thing you really need is a trans cooler for your auto.
I use a cargo carrier on my '94 and i would not even think twice about towing a small trailer with a simple fishing boat
Old Jul 28, 2006 | 05:51 PM
sony224422's Avatar
how do you hook up a tranny cooler?
Old Jul 31, 2006 | 11:09 PM
ricebike's Avatar
2 ways:
u can hook up one of the lines from the trans to the radiator & link the cooler "in series"
pro: in cold winter months, you'll have the benefit of warming up that fluid via the radiator tank...
other way is to undue the lines going to the radiator & hook both of them up to the cooler as a stand-alone unit: which is then, normally mounted in front of the AC condensor
PRO: when you have an overheating cooling system, your tranny won't bite the dust as well...
I like the 1st option though
Manolo
18
Dec 10, 2014 12:58 PM
vtecpros
59
Mar 16, 2010 05:46 AM
jman245
Honda Fit
Jul 22, 2007 08:37 PM
1989Prelude
Oct 12, 2005 05:29 PM
