tapin into stock headunit
Old Jul 24, 2006 | 08:05 PM
thatasiankidtony's Avatar
Default tapin into stock headunit
Hey everyone I'm planning to tap into my stock headunit usin this Rca thing...how would I go about doin that. (1997 accord Se) Stock cd player. I got this from a friend that pulled it off his eclipse.
Old Jul 24, 2006 | 08:30 PM
94_DC4's Avatar
Default Re: tapin into stock headunit (thatasiankidtony)
Have you ever used one of these converters before?
Old Jul 24, 2006 | 08:33 PM
94_DC4's Avatar
Default Re: tapin into stock headunit (SiRGDC)
Oops sorry. The white wires and grey wires are to be tapped into the front speaker wires on the stock harness, the brown wires are to be grounded to the cars chasis. Go to installdr.com to get the diagram for your car.
Old Jul 27, 2006 | 07:28 AM
ccjustin's Avatar
I generally put the line-level converters off the rear speaker leads, white+ wht/blk - for driver side, gray+, gry/blk- for passenger side. the brown wire(s) only need to be grounded if you have no or little output. I've never needed them on a honda. factory colors for the rears are, LR +/- blue/yellow - gray/white and RR +/- red/yellow - brown/white your switched power is white/red. good luck
Old Jul 27, 2006 | 07:47 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> the brown wire(s) only need to be grounded if you have no or little output.</TD></TR></TABLE>
Ditto that...
Old Aug 3, 2006 | 02:07 PM
I'm sorry I looked at install dr. I still got confused...Can someone reword that for me?
Old Aug 3, 2006 | 02:50 PM
B18C_EJ8's Avatar
If you can't understand the simple color codes, you shouldn't be working on your car. Pay a professional to do it before you fry something.
r1ch
Dec 13, 2006 08:49 PM
rough_draft
Audio / Security / Video
Mar 30, 2004 02:02 PM
(__________)
May 19, 2003 01:07 PM
Revtoredline
Mar 17, 2003 05:23 PM
fcuked
Oct 7, 2002 12:47 PM
