quick turbo ?'s i need answered
Old Jul 24, 2006 | 07:34 PM
ek4__'s Avatar
Default quick turbo ?'s i need answered
ive just installed my turbo the other week and i keep running into problems that are confusing me.
1st off...a/f gauge...am i suppose to hook it up half way from the o2 senor or can i just hook it straight to my ecu (p28 D14)
2nd...i dunno if my a/f gauge is not working right but my a/f gauge jumps from lean to rich once the car is warmed up. whats the best way to fix it, if im running too lean or rich. also what do i want it to be sitting at?
Old Jul 24, 2006 | 07:49 PM
siblues's Avatar
Default Re: quick turbo ?'s i need answered (ek4__)
I wouldnt even use the a/f gauge.The only thing those gauges do is pretty much just light up.The only gauges that actually read whats going on is a wideband o2.I am sure you will get the same response from a few people on here.
Old Jul 24, 2006 | 09:37 PM
ek4__'s Avatar
Default Re: quick turbo ?'s i need answered (siblues)
so whats a reasonable wideband o2 i could buy.
Old Jul 24, 2006 | 09:53 PM
ek4__'s Avatar
up... ....so for now if im not throwing out a CEL code for running rich or lean i should be ok to drive my car?
Old Jul 24, 2006 | 10:27 PM
dpetro1's Avatar
a/f gauges dont do much. the narrowband signal they recieve is way too sensitive. a wideband is the way to go. plx is a great company as well as the aem unit. you can get a gauge type with from either company.
Old Jul 25, 2006 | 05:39 AM
rmcdaniels's Avatar
Default Re: quick turbo ?'s i need answered (dpetro1)
I see the AEM Uego gauges go for around $250 with a sensor. I've been using the AEM Bosch/Uego setup for years and I like it, plus it comes with a gauge that fits in a standard-sized gauge pod.
If you do use an A/F gauge, you can hook it up at the ECU, although I hooked my old one up under the center console where the wires from the sensor come up through the floor. It should jump around normally, that is correct operation. What you are looking for is to see it go rich under boost, it should always go solidly rich under boost. If it shows anything other than rich under boost, stop boosting immediately.
Old Jul 25, 2006 | 05:55 PM
ek4__'s Avatar
Default Re: quick turbo ?'s i need answered (rmcdaniels)
thanks for the help.... ...i love this place
DarkBB4
Sep 4, 2004 03:27 PM
confidence
Feb 27, 2004 01:38 PM
spike
Jan 26, 2003 10:48 PM
1.8T_EG
Aug 23, 2002 05:21 PM
metal-x
Jul 24, 2002 02:25 PM
