GC Spring Rate Question
Old Jul 24, 2006 | 07:15 PM
mikeunreal2's Avatar
Default GC Spring Rate Question
What kind of spring rates do I want to look for for a daily drivable car? They would be matted up with Koni shocks. I just need something that will lower me about 2.5 inches all around and give me a nice solid ride. (solid=good and comforable, slightly stiff)
Mike
Old Jul 24, 2006 | 08:00 PM
chrisw85's Avatar
400 Front, and 400 rear.
I actually have 400F 375R but i could go a little bit stiffer, i have standard length but spss3 valved konis (some would say overkill for these low rates). I think I need to raise my car about 1/8"....the ride is not bad at all. I'm sitting at 5-1/4" measured at front jack point, and 5-1/2" measured at the rear jack point. This gives me about 1.5-1.75 'finger' gap and around 1" of shock piston travel. I do have tophats so that helps.
Other than that make sure you have fresh OE rubber bushings, esp the trailing arm ones, a good alignment, and good tires.
Old Jul 25, 2006 | 04:17 AM
Default Re: (chrisw85)
Do the GCs come with tophats? What else do i need to buy ex fo the konis and gcs?
Mike
Old Jul 25, 2006 | 05:08 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (mikeunreal2)
Go with the "off the shelf" rates.
ANNiHiLATORS
Suspension & Brakes
23
Sep 12, 2014 03:32 PM
bnetkillzone
Suspension & Brakes
75
Feb 15, 2012 11:47 AM
uses0ap
Jul 4, 2009 07:44 AM
USCdrifter
Apr 27, 2002 01:18 AM
Neo
Jan 10, 2002 04:37 AM
