del slo engine swap question
Old Jul 24, 2006 | 06:30 PM
ci_v_ic's Avatar
Default del slo engine swap question
alright i just bought a 93 del sol si with a d16z6, 20 miles down the road the son of a bitch THROWS A ROD THROUGH THE BLOCK!!!!!! so i have a readily accessible d15b7 block here at my house. can i take my z6 block out and just swap in the b7(it was freshly rebuilt)??? or would i have to do a different cam gear, take the oil jet out of the block and all that junk?? please need some info so i can figure out if i wanna just get a z6 longblock. thanks in advance
Old Jul 24, 2006 | 08:33 PM
ci_v_ic's Avatar
Default Re: del slo engine swap question (ci_v_ic)
help PLEASE!!!!! im having trouble finding a way to work w/o my car lol
Old Jul 24, 2006 | 08:38 PM
axtran's Avatar
just wait, jeez
Old Jul 25, 2006 | 09:13 AM
ci_v_ic's Avatar
Default Re: (axtran)
Old Jul 25, 2006 | 09:22 AM
Raggedyman's Avatar
Default Re: (ci_v_ic)
You'll essentially be doing a mini-me swap, but luckily you already have all the wiring in place so this should be a piece of cake. Yes...the oil jet will have to be pulled from the old D15 block but other than that a new head gasket and new Z6 timing belt and you should be all set. Read up on the mini-me swap ahead of time just to make sure you know the steps but this should be prettysimple and straightforward. The wiring is usually what gets most folks screwed up....but you already have all that AND the P28 ecu. Good luck!
Old Jul 25, 2006 | 02:58 PM
ci_v_ic's Avatar
Default Re: (Raggedyman)
cool man thanks!!
Old Jul 25, 2006 | 03:06 PM
ci_v_ic's Avatar
do you happen to have that write-up of the mini me that someone did a while back?? i used to have it but had to restore my computer and i didnt back it up.
BUB89
11
Sep 12, 2011 10:49 AM
Edison Carasio
Jul 14, 2010 01:02 PM
SSC_DelSlow
May 27, 2009 06:42 PM
RedRevolver
Feb 4, 2009 07:58 PM
purple98ek
Jun 3, 2005 03:01 PM
