DYNO results US vs other countries
Old Jul 24, 2006 | 05:38 PM
94vtirozguy's Avatar
Default DYNO results US vs other countries
I have noticed over the years the US dynos give a lot higher reading than other countrues.
The only thing i can put it down to is what is configured on the DYNO for drivetrain loss.
What is the typical setting set for preludes in the US ??? I read article about exact figures years ago and can't find it anywhere.
Old Jul 24, 2006 | 05:41 PM
98vtec's Avatar
moderator emeritus
Default Re: DYNO results US vs other countries (94vtirozguy)
some countries use a different unit of measurement. And in many cases the numbers you see are lower. HP and Tq arent the only way to measure power.
Old Jul 24, 2006 | 06:21 PM
yeah i know we use metric kw, and Nm.
after the conversion it still does not explain the 15% differential right across the board. Thats why the drive train loss configured on the dyno could explain this consistent differential.
Old Jul 24, 2006 | 06:44 PM
MLBZ521's Avatar
Default Re: (94vtirozguy)
Well, differences in sea level and climate can also come into effect couldn't it?
Old Jul 24, 2006 | 06:49 PM
98vtec's Avatar
moderator emeritus
Default Re: (MLBZ521)
yes. as well as tire pressure and how the dyno was calibrated. There are many things that can throw off the numbers.
Old Jul 24, 2006 | 08:02 PM
preludese111's Avatar
Default Re: (98vtec)
^^^exactly. And, if you look at dyno numbers w/in the US, you'll find that many of them vary a lot even w/ similar mods. Different dynos have very different results.
Old Jul 25, 2006 | 02:03 AM
found it... there is 15% difference the way american dynos are setup compared with aussie dynos.
B20vEf9
19
Jul 18, 2011 11:16 AM
skata89
Mar 18, 2007 08:07 AM
Norcalstoppy
Sep 28, 2005 06:48 AM
slimbo
Aug 8, 2002 03:51 PM
