severe ecu problems...please help!! pw0
Old Jul 24, 2006 | 05:23 PM
civickid03's Avatar
Default severe ecu problems...please help!! pw0
Ok, i was attempting to rig up my vss (electronic) to my pw0 ecu for my b16a1. i accidentally cut the wrong wire - b12 to be exact (b16 is the necessary wire to cut for vss). i didnt realize this right away, instead i connected the power wire from the vss to b12. i started the car and realized that there was a code 4 and it was running in limp mode. i disconnected all vss wires and reconnected b12 - my car still throws a code 4, why? i do not know. is it possible that i fried my ecu? im running out of ideas, ive traced and retraced crank position sensor wires c01 and c02 thinking that maybe these wires became loose. what other wires on the A, B, or C clips might cause a code 4. p.s. anyone in the philadelphia area wanna help me with this during the weekend??? anyone have a pw0 for sale?
Old Jul 24, 2006 | 06:28 PM
94VXLSHatchie's Avatar
Default Re: severe ecu problems...please help!! pw0 (civickid03)
maybe try resetting your ECU, pull the 15amp fuse from the engine bay fuse box, or also maybe disconnect the battery...hope this helps.
Old Jul 24, 2006 | 06:33 PM
fourthgenhatchB17's Avatar
Default Re: severe ecu problems...please help!! pw0 (89crxsohcvtec)
If u find out that u fried your PW0, i have a spare i can sell you. PM me if interested.
I remember when i burned out an ECU i could actually smell it when I removed the ecu cover. It sucked...but give it a sniff
Old Jul 24, 2006 | 06:35 PM
civickid03's Avatar
pulled the 15 amp, i always disconnect the battery every time i do ecu work......what other wires might affect the ckp? i did a mpfi on my dx harness which wires should i check - resistance wise/continuity wise?
88_lsvtec_hatch
Sep 22, 2006 08:32 AM
AzntaggeR
Feb 19, 2006 06:54 PM
EFz6er
Nov 1, 2005 08:03 PM
zccr-xsi
Sep 11, 2005 07:51 AM
