Advise on sleeves
just bored it out and hone it, save youself a big headache, everytime you pop out the piston you'll most likely have to bore it out and hone it and get new rings, and no thats not normal, especially the marks on the side of the sleeve
i wouldnt say thats slap or normal wear. it almost apears the the piston or cylinder aren't completely round. What i have saw from piston wear is a big area that is warn no a couple spots like that. if your just tring to get it back to normal i would just hone it. but if you're building it up bored it out 20 over and slap some new piston & rings in it. You may want to check your clearance on your bearings too... it may have too much causing the pistons to be slightly digging into the cylinder wall. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">no thats a clearnace problem</TD></TR></TABLE>
care to explain?
care to explain?
