IM ABOUT TO SHOOT THIS CAR!!!! HELP, if you can
I'm having a bit of a problem here, after the tune on this car it was working beautiful, no problems.Then after some time i started getting this stupid wat im guessing is ignition cut, i had replaced the dizzy brand new before the tune.So then after some time had passed it would start cutting out and doing this TATATATA around after vtec, mind you it ONLY DOES IT SOMETIMES, as if it has a mind of its own, which is really pissing me the expletive off like no other, i replace the cap and rotor cause the rotor looked pretty fried. i tried regapping the plugs down to .25 from .28 but thinking i know it cant be the plugs, cause after the tune it was perfect, so thinking after the new cap and rotor i thought i fixed it, but guess again, i didnt. Is it possible for a 1-3 month old dizzy, the parts inside coil and igniter go bad?
Plugs im using are ngk 7s, i was using 8's before but changed them, i was looking at the coil in the dizzy, and looking at the lil coil spring, looks kinda caroded on the spring, have no idea wat it is, all i know is its really pissing me off, i have been practically pulling my damn hair out cause of this, buying this buying that. PLEASE HELP IF U CAN, TIA
BTW - its a gsr
BTW - its a gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">
sounds like it could be the ignitor, have you tried a different dizzy and double checked timing?
havent tried differnet dizzy's cause i would need to borrow it for a while till it does it again, this bull **** only does it when it wants to. EXACTLY, that is wat i want to do to the ****, BREAK YO SELF CAR!!!
Ignitor is shot! i went thru 3 before i said expletive it!
Going with M&W pro 10 setup! Acutally just purchased one from Art few minutes ago hahah...but yeh stock ignitors are crap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon »</TD></TR><TR><TD CLASS="quote">Ignitor is shot! i went thru 3 before i said expletive it!
Going with M&W pro 10 setup! Acutally just purchased one from Art few minutes ago hahah...but yeh stock ignitors are crap...</TD></TR></TABLE>
i was either thinking coil or igniter, but why would it cause it and only do it sometimes? i could be rolling in 1st gear, get on it start boosting after vtec, then this tatatata ****, popping, or one day or 5 min later, from 1-3 it can be beautiful
Yeh becuase the ignitor is going bad...same thing happens to me...i would do a few good pulls flawlessly then that breaking up crap would start...i can actually smell the raw fuel not being burned...i mean your ignitor would be good for dd and low boost...but it wasnt made to ignite that fast on high boost...some people get lucky and get away with stock iginiton for a while...but rotors and caps go out, coils go out, and soon enuff the ignitor goes...
So instead of messing with the headach of changing crap out...i decided to upgrade...you may want to consider the msd billet distributor, msd ignitor, and ss coil, heard people do well on that so far, the price difference from m&w and that setup maybe 150-200 cheaper...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon »</TD></TR><TR><TD CLASS="quote">Yeh becuase the ignitor is going bad...same thing happens to me...i would do a few good pulls flawlessly then that breaking up crap would start...i can actually smell the raw fuel not being burned...i mean your ignitor would be good for dd and low boost...but it wasnt made to ignite that fast on high boost...some people get lucky and get away with stock iginiton for a while...but rotors and caps go out, coils go out, and soon enuff the ignitor goes...
So instead of messing with the headach of changing crap out...i decided to upgrade...you may want to consider the msd billet distributor, msd ignitor, and ss coil, heard people do well on that so far, the price difference from m&w and that setup maybe 150-200 cheaper...</TD></TR></TABLE>
yeah, i do smell this oder when its doing that ****, like fuel or something, but is it really that possible for a 1-3 month old dizzy to have parts go bad? after the tune it was working great, i guess it was just wearing out after time, im only boosting 10 pounds. Its a Distributor King dizzy.
try borrowing a freinds distributor...my guess is ur ignitor is gone...try asking dizzy king for another...more likely that one will prolli go out to in a few months...but u never know...it mite last ya...surprised urs went out at 10 psi...double check ur plugs and what gap are u running?
was running .28 then went down to .25, but cant be the gap, cause i was running the same gap during the tune
The coil went out on my Distributor King Dizzy in 1500 miles...similar problems until one day it just crapped out completely. That'd be my first look...
since you're in socal you can come by and try out a spare dizzy i have. it's obd1 dual vtec. PM me if you're interested. located in carson by the way.
I have a shotgun and some buck or a slug, I can certainly help you shoot it.
go back to -8 plugs (i run -9). you need the colder range and put the gap at 25 if under 12lbs, otherwise go to .22
could be igniter or coil, but check your plugs, first, it's cheaper than the other 2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">I have a shotgun and some buck or a slug, I can certainly help you shoot it.
i was using 8s before, it was doing it when i had 8s also, but not as bad, then switched to 7s and then i thought it went away completely, but i think thats when the dizzy was starting to take a ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote">since you're in socal you can come by and try out a spare dizzy i have. it's obd1 dual vtec. PM me if you're interested. located in carson by the way.</TD></TR></TABLE>
thanks man, appreciate it, but im still using the obd2 harness that means im still using obd2 dizzy, and thing is i would need the dizzy for a while to see if it does it, lol thank you though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi »</TD></TR><TR><TD CLASS="quote">The coil went out on my Distributor King Dizzy in 1500 miles...similar problems until one day it just crapped out completely. That'd be my first look...</TD></TR></TABLE>
thank you, i guess it really can happen then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">just something else to consider.. for some reason mine acted this way when my headgasket went..
since i replaced it i don't have this issue</TD></TR></TABLE>
pretty sure its not the HD, compression is still good, just did a test not too long ago, thank you for the idea
well i ordered the igniter and coil, i hope it works, this is starting to get very frusterating like no other, im ready to call it quits on this car, i dont know how something could be working so good for a period of time, then start ******* up. *SIGH* feels like a ******* rev limter and ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">yeah sounds like ignitor, what map are you running by the way?</TD></TR></TABLE>
which map?
which map?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH »</TD></TR><TR><TD CLASS="quote">which map?</TD></TR></TABLE>
yeah what map sensor (manifold absolute pressure) are you running? OEM? 3bar? 2.5bar?
Cause i know oem will only read like ~11psi after that you will start getting weirdass issues.... on my last boosted project i was boosting 10psi on stock map and if it ever even slightly crept or overboosted it would hit a hard fuel/ignition cut
just something to consider
oh my bad, duh me, yea stock map, thing is it wont even let me reach full boost. starts to cut, somedays it works some days it doesnt more doesnt than does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon »</TD></TR><TR><TD CLASS="quote">Wierd! After having igntion cuts....my ignitor seems to work ok today..did good pulls up to redline at 14 psi....some days it works, some days it doesnt...wierd ****..</TD></TR></TABLE>
YES!!! very weird ****, pissing me off
i think i figured out my problem, i believe it was the hondata 2 step, after i unplugged it from the blue box, i havent had any problems yet, and its been 5 dayssince it happend, so....so far so good
edit - now 6 days so far so good
Modified by SPNFEDEH at 1:01 PM 8/18/2006
egluism33
May 25, 2008 06:17 PM
hondatuner123
Feb 23, 2006 12:04 PM
b18apwr
Oct 9, 2002 12:36 PM
