obd0 to obd1
Old Jul 24, 2006 | 02:04 PM
projsectEF's Avatar
Default obd0 to obd1
if I get a obd0 to obd1 ecu jumper harness and use a 94 civic ex ecu, would i have to change anything with the dpfi to mpfi conversion i have done?
how would I hook up the obd1 dizzy? does anyone have a diagram of how I would hook up the obd1 dizzy to the obd0 engine harness?
Old Jul 24, 2006 | 05:32 PM
projsectEF's Avatar
Default Re: obd0 to obd1 (projsectEF)
please help. im really need help. all this conversion stuff is confusing me.
Old Jul 24, 2006 | 05:48 PM
Hella_Fresh's Avatar
covert to mpfi
convert to obd1 dist.
you have to either convert the dist plugs your self or buy one from http://www.rywire.com
Old Jul 24, 2006 | 05:53 PM
highrev1987's Avatar
Default Re: obd0 to obd1 (sXekid)
the conversion to obd1 will have you make the mpfi work a little differently. you should: (easiest way) by a boomslang/rywire jumper, get some obd1 injectors (so you dont have to rock the resistor box, and read this---> http://www.boomslang.us/obd0_1.pdf happy converting
Old Jul 25, 2006 | 12:27 AM
projsectEF's Avatar
how do I convert the dizzy wires myself. is there a wire diagram that I can follow?
Im going to buy the obd0 to obd1 ecu wire jumper,
so if anyone has info on how to hook up the obd1 dizzy to the obd0 harness please help.
Old Jul 25, 2006 | 12:32 AM
search it up man, i know theres tons of write ups on here.
dr_latino999
236
Mar 28, 2020 12:34 AM
4g4dcruisin
Feb 3, 2010 03:06 PM
949
Jul 4, 2009 09:18 PM
yamaha250f101
Mar 13, 2005 09:36 PM
