Rear end feels very loose
Old Jul 24, 2006 | 12:11 PM
TommyBB's Avatar
Default Rear end feels very loose
I have no clue what happened just driving and heard a klunk then the rear end feelt really loose. I jack up the back and looked and I couldnt see any damage or anything broken. could it just be an adjustment??
Old Jul 24, 2006 | 12:17 PM
y-49's Avatar
what kind of car
Old Jul 24, 2006 | 12:38 PM
thesmogman's Avatar
Default Re: Rear end feels very loose (TommyBB)
I take it it's the 91 right.
How I found my bushing's were bad was kicking the tire forward and backward.
Compare the movement with the other side. Should move like 1/8" not 3/4"
This is for the trailing arm. To check the rest out, jack the car up and do the wiggle test. Push in and pull out on the top of the tire, then bottom and so on. Once you find it get a friend to wiggle and look to see where the slop is.
Old Jul 24, 2006 | 07:11 PM
ViSioN.GSXR.'s Avatar
why does your rear end feel loose
haha
Old Jul 24, 2006 | 08:25 PM
fiff gurr vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViSioN.CRX. &raquo;</TD></TR><TR><TD CLASS="quote">why does your rear end feel loose
haha</TD></TR></TABLE>
lmao..might need a rebuild after the wiggle test
Old Jul 24, 2006 | 08:34 PM
Rednas's Avatar
Default Re: Rear end feels very loose (spankmaster)
bushing, your car is at least 15 years old by now, regardless of how much care you take care of the car there are some parts that are bound to be worn out.
Old Jul 25, 2006 | 05:24 PM
TommyBB's Avatar
Default Re: Rear end feels very loose (Rednas)
I just put in all new bushings less than 3 months ago. energy suspension. but it still feels weird. maybe my tires? I checked and made sure that they were all at 32psi. but it still feels loose when cornering. yes it is a 91 civic si. koni fully adjustables. tommorow I plan to lift it up and check all the bushings and all my suspension parts and make sure all the bolts are tightened.
Old Jul 25, 2006 | 06:10 PM
godruler's Avatar
probrabbly trailing arm bushings, they always go shot because of their design, check this out http://www.drivewire.com/honda....html they have replacedments, rubber too not poly garbage for a pretty good price, or search for the mugen rubber replacements online, i've heard they are much stiffer rubber.
Old Jul 25, 2006 | 06:21 PM
rsca_crx's Avatar
Default Re: Rear end feels very loose (godruler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godruler &raquo;</TD></TR><TR><TD CLASS="quote">probrabbly trailing arm bushings, they always go shot because of their design, check this out http://www.drivewire.com/honda....html they have replacedments, rubber too not poly garbage for a pretty good price, or search for the mugen rubber replacements online, i've heard they are much stiffer rubber. </TD></TR></TABLE>
the honda ta bushings are available individually, and are very close, if not the same, to the mugen bush's. the topic has been beaten around for a while here and in the rr/ax forum.
Old Jul 25, 2006 | 11:05 PM
sirrvanna's Avatar
Default Re: Rear end feels very loose (rsca_crx)
u kno it's against the law to have sexual relations wit the car, better get that rear end up and tight again
97civic07gsxr
Mar 30, 2009 05:06 PM
chinochanginc
Feb 4, 2009 04:01 PM
teletekman
Suspension & Brakes
Feb 10, 2006 01:20 PM
