Noobish question.
Old Jul 24, 2006 | 12:02 PM
Vitesse's Avatar
Default Noobish question.
If i take off my valve cover.. will i have to replace the gasket .. or can i use the original?
Old Jul 24, 2006 | 12:03 PM
Vitesse's Avatar
Default Re: Noobish question. (Vitesse)
p.s. please easy on flamming.
Old Jul 24, 2006 | 12:10 PM
rgaray's Avatar
Depends on how many miles since you replaced it. Although, it's only $10-12 @ the dealer, so why not just replace it.
Old Jul 24, 2006 | 12:11 PM
Vitesse's Avatar
Default Re: (rgaray)
I just bought the car.. and i really have no idea when it was last changed.. i understand how cheap they are.. but i just want to check things out in there so i was only curious.. might aswell wait.
Old Jul 24, 2006 | 12:14 PM
ejmatzell's Avatar
Default Re: (Vitesse)
just took my valve cover off to repaint, and used the same gasket when i put it back on. my car is at 150k, and the gasket (being the original) looks just as good as a new one. some people, although i didn't do it, recommend using some type of cocking stuff (name?) on the corners to make sure the seal is perfect.
Old Jul 24, 2006 | 12:29 PM
Vitesse's Avatar
Default Re: (ejmatzell)
thanks man.. it makes sense that i could use the orig.
Old Jul 24, 2006 | 12:32 PM
Benard's Avatar
as long as the valve cover comes off without ripping the gasket, i would say its fine
Old Jul 24, 2006 | 01:24 PM
danny99si's Avatar
Default Re: (Benard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benard &raquo;</TD></TR><TR><TD CLASS="quote">as long as the valve cover comes off without ripping the gasket, i would say its fine</TD></TR></TABLE>
Old Jul 24, 2006 | 01:26 PM
tomithy's Avatar
i just replaced mine a few days ago, used that silicone gasket sealer stuff and reused the old gasket
Old Jul 24, 2006 | 01:50 PM
MISTER TRANCE's Avatar
^^ same. then again, cheap valve cover gaskets are ftw if you want peace of mind!
Old Jul 24, 2006 | 02:04 PM
Rainville's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitesse &raquo;</TD></TR><TR><TD CLASS="quote">If i take off my valve cover.. will i have to replace the gasket .. or can i use the original?</TD></TR></TABLE>
Replace it, then u know how old it is. Use high temp silicone caulk around the cams. Better safe than sorry
Old Jul 24, 2006 | 02:10 PM
Uncle Willie's Avatar
Default Re: Noobish question. (Rainville)
Yup, Honda bond or something similar.
Old Jul 24, 2006 | 02:31 PM
victorious1's Avatar
it is re useable as long as it is not torn. but like they mentioned earlier you need to use honda bond or some ultra grey silicon from auto zone. around the end of the cams.
Old Jul 24, 2006 | 02:35 PM
jared99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitesse &raquo;</TD></TR><TR><TD CLASS="quote">p.s. please easy on flamming.
Is the flam about to start?
squire
Mar 10, 2008 03:40 AM
porter
Feb 16, 2007 01:46 PM
92ehatch
Jan 3, 2006 08:52 AM
4DRmafia
10
Jun 29, 2004 08:35 PM
4crx4me
Jun 8, 2004 03:23 PM
