Question about timing belt
Old Jul 24, 2006 | 10:16 AM
rwcdrums's Avatar
Default Question about timing belt
I've got a gsr turbo swap in my eg hatch. I'm rebuilding the motor and using a new oem type r oil pump and water pump. I had somebody tell me that I would need a longer timing belt and said that a stock gsr belt wouldn't work. Is this true?? thanks
Old Jul 24, 2006 | 11:03 AM
rwcdrums's Avatar
Default Re: Question about timing belt (rwcdrums)
bump for an answer
Old Jul 24, 2006 | 03:44 PM
NJIN BUILDR's Avatar
Itr,gsr,ls w/ls water pump = Ls timing belt
Itr,gsr,ls w/gsr,itr,b16 water pump = Itr or gsr belt (same belt)
The oil pump doesn't make any difference in timing belt length
Old Jul 24, 2006 | 03:58 PM
egsleepercivic's Avatar
it has to do with the number of teeth of on the pump and belt
Old Jul 24, 2006 | 08:35 PM
rwcdrums's Avatar
Default Re: (egsleepercivic)
so gsr will be fine?
Old Jul 26, 2006 | 01:05 PM
I believe the gsr and type r belts are the same
Old Jul 26, 2006 | 02:44 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I believe the gsr and type r belts are the same</TD></TR></TABLE>
GearheadzAuto
Jan 3, 2008 07:58 AM
1990_integra_DA9
Aug 3, 2007 02:24 AM
Bictorious
May 9, 2004 08:27 PM
BoOsTiN Dc2
Feb 7, 2004 04:49 AM
infamousALLMTR
Feb 25, 2003 07:17 PM
