is my flywheel going
Old Jul 24, 2006 | 09:03 AM
DB1_559's Avatar
Default is my flywheel going
ok so i was just wondering cause i like have to let my rpm drop to like idle to changed gears is that normal for a 93 da.i was reading something bout flywheels and it sound like a flywhell issue not sure any help. thanks
and why is my clutch pedal so tight
ps. stock clutch/flywheel
Modified by jdmboi86 at 10:49 AM 7/24/2006
Old Jul 24, 2006 | 09:11 AM
DB1_559's Avatar
Default Re: is my flywheel going (jdmboi86)
yea so if i change gear with the rpm going to idle it grinds i have to go straight to idle for a smooth shift
Old Jul 24, 2006 | 09:15 AM
JunkyardGSR's Avatar
flywheels dont go bad, they have to be resurfaced everyonce in a while (like when changing a clutch disc) but that's not your problem. If it grinds when you try to shift it, or doesnt want to go into gear when it used to... chances are your Syncros are going out. If it's consistently the same gears, thats what it is.
Old Jul 24, 2006 | 09:18 AM
DB1_559's Avatar
but i heard a lighter flywheel makes your rpm drops faster
Old Jul 24, 2006 | 09:39 AM
Khelm's Avatar
"but i heard a lighter flywheel makes your rpm drops faster"
.... Ok that is true but that has nothing to do with you shifting gears... Your flywheel and your tranny are not one in the same..
In any case JYGSR has your awnser your syncros are bad not the flywheel.
Old Jul 24, 2006 | 09:43 AM
DB1_559's Avatar
bump need a tranny now
Old Jul 24, 2006 | 12:23 PM
new syncros do not mean a new tranny. In fact, bad syncros are a pretty common problem, especially in cars with a bad history of shifting abuse. Take it to any transmission shop and they will replace the syncros for a few hundred bucks. If youre feeling ducky, you can do it yourself... it's actually not that hard if you have a Chilton's manual.
Old Jul 24, 2006 | 12:28 PM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyardGSR &raquo;</TD></TR><TR><TD CLASS="quote">new syncros do not mean a new tranny. In fact, bad syncros are a pretty common problem, especially in cars with a bad history of shifting abuse. Take it to any transmission shop and they will replace the syncros for a few hundred bucks. If youre feeling ducky, you can do it yourself... it's actually not that hard if you have a Chilton's manual.</TD></TR></TABLE>
i knew but i rather buy a new tranny cause it cost bout 500 bucks to repair
meanshyguy
Sep 4, 2009 08:06 AM
Tad
46
Mar 2, 2005 11:05 AM
ActiveAero
Jan 4, 2003 08:50 AM
Lyonel
Dec 16, 2002 07:14 AM
