HELPPP!!! Loose and wobbly hub and rotor??!!!
Old Apr 22, 2002 | 02:34 PM
RenoRacing's Avatar
Default HELPPP!!! Loose and wobbly hub and rotor??!!!
hey guys, i really need help.
I'm now having my first problem with my ls/vtec swap into my ef hatch. it's got over 500 miles on it now and all of the sudden i started to hear this slight thumping/ rubbing noise that increased with my speed. i got home and jacked it up and it turns out that my passenger front rotor and hub is really wobbly. I tightened the usual rotor screws(phillips ones) but it is the whole hub that seems wobbly. I don't know what i need to do, i checked all the suspension bolts and contolarm bolts and they're all tight. Is it something wrong with the joint in the axle or something, they're brand new napa axles for 90-93 integra. I just don't get what came loose that was fine the whole time before.
somebody please try to help me out!!!
Old Apr 22, 2002 | 08:28 PM
hatchmobile's Avatar
Default Re: HELPPP!!! Loose and wobbly hub and rotor??!!! (HavokRacing)
you might have a bad wheel bearing...i would check that out. i had the same problem and it's really annoying
Old Apr 22, 2002 | 10:24 PM
b19coupe's Avatar
Make sure that the 32mm axle nut is tight.If it's tight, then most likely you have bad wheel bearing.
wunPOINTeight
Jun 15, 2021 06:37 PM
jackmode9316
Nov 23, 2007 12:09 PM
WPeters
Nov 15, 2007 02:07 PM
RenoRacing
Apr 23, 2002 04:32 AM
RenoRacing
Apr 22, 2002 09:26 PM
