clutch ?
Well...atleast for B series, you could use a hydro pressure plate if you use the hydro flywheel...and for B 92-93 has the same input shaft as a hydro tranny....so if this is D i am not sure about the clutch disk but it should be the same...in general:
Match the Clutch disk to the tranny
Match the flywheel and pressure plate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT »</TD></TR><TR><TD CLASS="quote">depends on what tranny you are going to. The spline count for the input shaft must be the same.</TD></TR></TABLE>
Not 100% true for B maybe D....but the 90-91 B tranny's have the same # of splines but the thickness is minutelly different then the 92 and up
i have a d-series si tranny and i want a lighter flywheel and it is hard to find one for the cable tranny so i was just wonderong if i could use a flywheel preasure plate and clutch from a hydro tranny?
All 89-00 flywheels are the same and all 90-00 clutches are the same, though an 89 clutch will work as well.
The only thing if that if you use a hydro clutch it need to be an 89-91 tranny and use a cable throwout bearing. You can also do this the other way around.
ACRXGuy
18
Nov 23, 2002 10:25 AM
