loud Wine noise under passanger side dash with A/C on
Old Jul 24, 2006 | 05:38 AM
B16CivicEX's Avatar
Default loud Wine noise under passanger side dash with A/C on
I have a 2000 Ex with a b16A, and when i turn the A/C on i get a loud wine from under the passanger side dash, it will come on for 1 sec, then go off, then 2-3min later it will come back and wine, then go off, same thing, over and over, i peeked underthere and can hear it but cant tell where its coming from, its only with the A/c on.. and it only wines for a seconed then goes off, then 1 min later it will wine loud again.. Any help would be great. Thanks!!!
Old Jul 24, 2006 | 05:49 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: loud Wine noise under passanger side dash with A/C on (B16CivicEX)
sounds like you have a leaf or something stuck in the blower. Is it when the fan is on, or just when the AC is on?
Old Jul 24, 2006 | 07:45 AM
B16CivicEX's Avatar
only when the A/C is on, i can run the fan, and no noise.
Old Jul 24, 2006 | 07:56 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (B16CivicEX)
Wine - an alcoholic drink made from fermented grapes and used primarily to remove female underclothes.
Whine - an annoying, high-pitched sound.
Old Jul 24, 2006 | 09:11 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
You have issues with your AC evaporator. This may be an easy fix or expensive depending on what is causing it to make the noise. Could be as simple as a faulty, loose, or noisy ThermalSwitch, or as expensive as a damaged or failing Exap core.
Old Jul 24, 2006 | 10:39 AM
B16CivicEX's Avatar
what is the best way to troubleshoot this
Old Jul 24, 2006 | 05:03 PM
B16CivicEX's Avatar
maybe this helps, when this whine started the a/c got about 20 degrees colder, it will freeze you out now?? weired.
Old Jul 25, 2006 | 04:16 PM
B16CivicEX's Avatar
up
Old Jul 25, 2006 | 05:16 PM
Hondaman56's Avatar
You need to remove the bottom Evap cover and see if its just a loose Theroswitch. I think you can access it that way. I am not sure if you can disconnect it with the system charged or not. Its a little tube like thing with leads on it. It should be pressed between the fins of the Evap core. What this does is sense the temp of the Evap core and when it reaches a certain cool temp it shuts the compressor off. Oce things heat up again it switches the compressor on and the cycle begins again. It sounds like you have a noisey one. You'll have to see if you can disconnect it without discharging the system. If so its not an expensive part.
guymontag
Feb 20, 2016 01:38 AM
mojoski
Jan 3, 2012 05:47 PM
Choy
Jul 1, 2009 09:50 AM
wesbroadway
Sep 12, 2007 03:29 PM
Brian Hinson
Jan 19, 2005 11:40 AM
