CTR cams VS. buddyclub spec III's
Old Jul 24, 2006 | 04:08 AM
jdm ek9 101's Avatar
Default CTR cams VS. buddyclub spec III's
I heard that civic type r cams are the most agggresive but what are the bc3's like compared to them is the v-tec still aggressive????
Old Jul 24, 2006 | 10:41 AM
Default Re: CTR cams VS. buddyclub spec III's (tj CTR)
help
Old Jul 24, 2006 | 11:02 AM
fkncivic's Avatar
need info on ur setup, of course aftermarket cams are gonna be more aggressive than an oem cam but depending on ur setup u might not want to go too big.
Old Jul 24, 2006 | 06:17 PM
LSV_REX's Avatar
Default Re: CTR cams VS. buddyclub spec III's (fkncivic)
Find out lifts and durations for each, and then compare to your setup.
Old Jul 24, 2006 | 08:51 PM
civicstar's Avatar
i say the BUDDYCLUB spec IIIs are alittle bit more aggressive
Here are the specs:
Type: Intake Lift: Intake Duration: Exhaust Lift: Exhaust Duration:
CTR 11.5mm 243 10.5 mm 235
BC3 11.59 304 10.7 mm 294
both intake and exhaust duration is alot longer. the longer duration allows for more high end power and the exhaust lift is 0.2 larger
Old Jul 25, 2006 | 04:21 AM
Takumi Fujiwara's Avatar
Default Re: CTR cams VS. buddyclub spec III's (civicstar)
Here is a physical comparison on this thread. These are the BC3+ though.
http://www.team-integra.net/fo...32273
Old Jul 25, 2006 | 08:42 AM
ramhorn15's Avatar
Default Re: CTR cams VS. buddyclub spec III's (Takumi Fujiwara)
what motor are you trying to put these cams in? And will this be all motor or boosted?
Old Jul 25, 2006 | 09:42 AM
Default Re: CTR cams VS. buddyclub spec III's (ramhorn15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramhorn15 &raquo;</TD></TR><TR><TD CLASS="quote">what motor are you trying to put these cams in? And will this be all motor or boosted?</TD></TR></TABLE>
You definitely don't want these cams for boost... there is alot of overlap.
Old Jul 26, 2006 | 05:57 AM
there going into a civic type r and i would love to boost but its too expensive.
DC2*Integra
May 13, 2004 07:43 PM
ThrillaKilla
May 7, 2003 11:35 PM
t616
Sep 9, 2002 12:20 PM
hybridreams
Feb 1, 2002 06:58 AM
