what do i need?
Old Jul 24, 2006 | 03:24 AM
EG type GTR
Guest
Posts: n/a
Default what do i need?
chassis 95 eg cx
motor jdm 98 itr
engine harness usdm obd2 gsr
ecu phearable p28
what exactly do i need to wire up to complete the swap? i currently have a cel with no vtec. i tried looking for the ecu plug to check the cel but i cant find it. theres no loose plug anywhere.
Old Jul 24, 2006 | 03:54 AM
thahuhstunna's Avatar
Default Re: what do i need? (EG type GTR)
ah, FAQ grasshoppah
https://honda-tech.com/zerothread/1171263
Old Jul 24, 2006 | 03:57 AM
EG type GTR
Guest
Posts: n/a
ive looked at that but im still confused as to exactly what i need to wire up for my particular application
Old Jul 24, 2006 | 03:59 AM
Default Re: (EG type GTR)
well that's a different question... check your cel first, find out what code it's throwing and work from there... update when you have the code, and you'll be able to get assistance on what else needs to be done
Old Jul 24, 2006 | 04:17 AM
EG type GTR
Guest
Posts: n/a
Default Re: (thahuhstunna)
from my understanding, i need to connect a4 and d6 on the ecu to 2 spots on the firewall side harness
i also understand i need to bridge a4 and d6 to bypass the oil pressure switch.
now, what i want to know is about the knock sensor and o2 wires.
im using a usdm obd2 gsr harness.
Old Jul 24, 2006 | 04:18 AM
EG type GTR
Guest
Posts: n/a
also, is there anything i need to do with the green vtec solenoid plug on the engine harness?
doctorake
Mar 25, 2012 08:01 AM
anzh86
Jul 31, 2011 05:01 AM
kcvi3tstyl3
Apr 20, 2009 06:17 PM
jdoggmr2
Jun 25, 2006 03:44 PM
Griffin@Camtech
May 25, 2004 08:54 AM
