Anybody have this type of radio antenna?
Old Jul 23, 2006 | 07:47 PM
BlueIntegraBoy's Avatar
Default Anybody have this type of radio antenna?
I was planning to buy this type of antenna and use a blockoff plate for my stock antenna. The reason being is that the metal nipple part of the connector that goes into the radio was broken since I had the car. I ghettoed it by using a paper clip to act as the nipple, but reception isn't clear and it seems to be getting worse.
If anybody has this antenna, any feedback is welcomed. Thanks.
Old Jul 23, 2006 | 07:55 PM
endlesswinterco's Avatar
Default Re: Anybody have this type of radio antenna? (BlueIntegraBoy)
up, cuase i want to know as well
Old Jul 23, 2006 | 07:59 PM
evochuck's Avatar
Default Re: Anybody have this type of radio antenna? (OEMben)
one of my friend shaved his and used this, works very well, you have to stick it to the side of your windshield
Old Jul 23, 2006 | 08:05 PM
Default Re: Anybody have this type of radio antenna? (evochuck)
I was going to run it up the a-pillar through the roof and mount it in the top center of the windshield.
Old Jul 23, 2006 | 08:37 PM
h22apwrdcivic's Avatar
yeah do that and let us know how reception is.
Old Jul 23, 2006 | 08:38 PM
Default Re: (h22apwrdcivic)
It looks like I will pick it up. Just gotta find out where I can.
Old Jul 23, 2006 | 08:46 PM
Draggin99Si's Avatar
I installed this back in 2002 when I had my antenna shaved. Reception is as good as stock if not better because the unit is amplified. I'm using a Metra hidden windshield antenna. One important thing is that placement of the unit is crucial to how good your reception is gonna be. At first, I stashed the antenna behind the cupholder area behind the console completely out of sight. Reception was horrible so I re-installed it the proper way by routing it up the passenger side piller then along the roof pillar. The plastic pillars conceal all wiring. By mounting it on the windshield, it has a direct line of sight towards the sky.
My antenna looks exactly like the one in your pic. I have it sitting on the very top front edge of the windshield where it sits in front of the rearview mirror. Here are pics of the antenna installed...........
Can you see even it?
You notice that you can't even see the damn thing from outside of the car because of how the windshield is slanted. It's practically invisible and unnoticable unless you actually sit inside the car. It looks very unconspicuous. Most of my passengers don't even notice it.
Modified by Draggin99Si at 10:01 PM 7/23/2006
Old Jul 23, 2006 | 08:51 PM
Default Re: Anybody have this type of radio antenna? (Draggin99Si)
Here I'm sitting in the driver seat.......
tHeeeazy E's Avatar
looks like the antenna for 2way pagers
Old Jul 23, 2006 | 08:54 PM
Awesome, looks great. Thanks for the pics. Where did you get yours from?
Old Jul 23, 2006 | 08:58 PM
Frozen E's Avatar
H-T White Ops
Where'd you get it? I need one because the one in my 94 is shot.
Old Jul 23, 2006 | 09:04 PM
Default Re: (IslandSi)
I got mine from Kragens for like $15. I think they also sell them at Autozone and Pep Boys.
Old Jul 23, 2006 | 09:05 PM
Default Re: (Draggin99Si)
Did you need to wire up a separate wire for power?
Old Jul 23, 2006 | 09:10 PM
Default Re: (BlueIntegraBoy)
I can't remember if I did or not.
It does have a tiny red LED on the face of the unit. Whenever you start the car, the LED lights up so you can see that the antenna is powered up. Then when you shut off the car, the LED turns off.
Old Jul 23, 2006 | 09:19 PM
Yeah, if it has an LED, most likely I'll need to power it up.
Old Jul 23, 2006 | 09:34 PM
There's a Kragen down the street from me. It's $15.99, going to pick it up tomorrow and install when I get home in 3 weeks.
Old Jul 23, 2006 | 10:17 PM
j spec's Avatar
i was gonna do that myself because my antennae has been broken for 3 years now. Turns out you can buy factory replacements for like 15.99 at radioshack, also most places keep them in stock. I was amazed to find this out after putting up with bad reception for 3 years now. Quick note: When you are replacing a factory one you can clip your old cable from out side the car and tape it to the radio end of the new cable, then simply pull the old cable out through the inside under the dash. (so you don't have to "fish" for the new cable in the pilar) This way it is very quick and simple and only took me about 10 minutes for the whole procedure.
Old Jul 23, 2006 | 11:48 PM
ironcheftony's Avatar
had 1 in my hatch, works just better than stock imo and is cleaner
Old Jul 24, 2006 | 05:35 PM
Default Re: (ironcheftony)
I just bought one from Kragen today. It's a little longer than I thought, but it shouldn't bother me. I'll install it in 3 weeks when I get back home and post pics.
Old Jul 25, 2006 | 03:07 PM
Milanoegg's Avatar
i have mine underdash, works well..but not best for me
Old Aug 17, 2006 | 02:58 AM
Well, I have gotten around to install it since I came home Sunday. Installation was really easy. There is a 12v wire that needs to be spliced into the radio harness for power and a ground up top.
I bought an antenna blockoff plate and yanked out the old non-functional antenna. If anybody needs a replacement antenna, I would recommend the Metra Hidden Antenna.
mamaboy
Jan 13, 2003 06:06 AM
feriocious
Sep 21, 2002 06:38 PM
xero-cool
Jun 10, 2002 11:26 AM
digitalspice
Audio / Security / Video
Oct 10, 2001 03:30 PM
