What do you use to jump the ECU to check a CEL?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londonsupra »</TD></TR><TR><TD CLASS="quote">i just cut the clip and twist the wires together when needed</TD></TR></TABLE>
Are you serious?
Are you serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">Are you serious?</TD></TR></TABLE>
yah i dont see what the problem is with that.??!
I hated ******* with a paper clip to get a connection so I just cut it off but left myself slack incase i ever needed to hook it back up for whatever reason.
I just use a short length of thick gauge wire. I guess I've never had a problem getting a connection, and have never felt the need to cut the wires nor the connector off...
I just cut a 2 prong plug off my car wiring harness from my totalled Accord EX. The I just removed one of the wires and looped the other one. So if you wanted, you could just go to a junkyard and cut a 2 prong plug, that'll fit, off a car and do the same thing I did. Or just use a wire or paper clip like philadd and YeuEmMaiMai said.
here is a picture of what I use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
They have something already like that in the steering wheel (on the bottom w/ two screws) IIRC it's called the ESM connector? Anyway, that's what I use.
</TD></TR></TABLE>They have something already like that in the steering wheel (on the bottom w/ two screws) IIRC it's called the ESM connector? Anyway, that's what I use.
yeah, thats the service connector for when you remove/replace the airbags I believe. You connect that to the airbag connection to help prevent the airbag from going off as your removing/replacing it. I want to say I remember reading that in the Helm manual, I may be mistaken though.
vestalfootball72
Jul 2, 2007 03:19 PM
94VXLSHatchie
Jul 6, 2006 07:22 PM
MattD@Stoptech
Jun 16, 2005 04:26 PM
