F.A.S.T. standalone not showing 12volts and won't start the car??? HELP!!!
Old Jul 23, 2006 | 04:42 PM
Ntense90crxsi's Avatar
Default F.A.S.T. standalone not showing 12volts and won't start the car??? HELP!!!
Well I had posted about a couple of problems I was having before but this is the only one left. Well the system comes on perfect, all sensors show correct readings and responding the way they should except the voltage. It will only show 2.4volts, even when I shut it off it responds correctly and goes to zero before it shuts off. I redid the connection on the battery of both the power and grounds and still the same thing. Any ideas would be great. I am trying to make a race on the 30th and need to finish this thing up. I am assuming the system won't run because of the low reading coming in, I am sure its some sort of safegaurd because it is not firing the injectors either. The whole system otherwise seems to be in perfect working order.
Old Jul 23, 2006 | 06:43 PM
Default Re: F.A.S.T. standalone not showing 12volts and won't start the car??? HELP!!! (Ntense90crxsi)
ttt
Old Jul 23, 2006 | 06:50 PM
mtber's Avatar
Get your multimeter out & call FAST tech support.
Old Jul 24, 2006 | 06:19 AM
Default Re: F.A.S.T. standalone not showing 12volts and won't start the car??? HELP!!! (mtber)
I never thought of that, lol, most of the time I just use Honda-Tech support, lol. I am gonna call them today. If anyone still has any input please add.
Old Jul 24, 2006 | 07:21 PM
figured it out, hopefully I will have it running tommorrow.
blind951
Sep 16, 2013 07:07 AM
[626]95-GSR
14
Feb 27, 2003 07:45 AM
see_fu
Oct 30, 2002 01:05 PM
FOrSfEd
May 27, 2002 09:26 AM
RedTeg_girl
Aug 21, 2001 08:02 PM
