is there a rebuild kit for a proportioning valve?
Just curious if anyone knows about rebuilding proportioning valves, if there is a part store/dealership that sells a rebuild kit for them.
johnny
johnny
theres not really anything inside that can be rebuilt, I have never seen one go bad but just buy a new one if thats your problem
mine is leaking from that little hole in the side, looks like there is a rubber seal there or something, but i am doing a rear disk conversion and replacing it anyway but i was wondering if there is a way to fix that in the meantime? I'm not really sure what that hole is for anyway but there is fluid leaking from somewhere and i tried to tighten the bolts up first but we shall see. I bought an integra prop valve at a junkyard for $3 so thats probably the one i will use in the future when i do the swap. Its off a 92-93 LS and its the same except the bracket is on the other side, so i was thinking of taking it apart and switching brackets but if i'm going to do that i was going to replace any gaskets the thing might have. I guess i'll just mess with it and see what i can find out. thanks though.
-johnny
-johnny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">no, you cannot rebuild the Honda proportioning valve. go grab a new/used one.</TD></TR></TABLE>
used on ebay = 15$
used on ebay = 15$
Colin
Suspension & Brakes
Sep 29, 2009 11:20 AM
Adi Radoncic
11
Apr 21, 2006 05:00 PM
