DIY hone/deglaze of cylinders?
Old Jul 23, 2006 | 03:52 PM
killerpenguin21's Avatar
Default DIY hone/deglaze of cylinders?
i just picked up a block to do a fresh bottom up motor build. The block sat in someones garage for quite awhile and the walls are kind of rusted and you cant easily see the cross hatch. The local engine shop wants to charge me 60 bucks to to run the hone through it real quick...
so my question is...can i do this myself? i dont imagine it is too difficult, and i can get the tool for 20 bucks (looks reputable) here -- http://www.eastwoodco.com/jump...ODUCT
any input?
Old Jul 23, 2006 | 04:12 PM
Hyaboosta's Avatar
Default Re: DIY hone/deglaze of cylinders? (killerpenguin21)
I belive you also need the beaded tool to run thru after the hone.
Old Jul 23, 2006 | 04:59 PM
Default Re: DIY hone/deglaze of cylinders? (Hyaboosta)
any more info on that?
Old Jul 23, 2006 | 05:18 PM
dinko's Avatar
id let the machine shop do it
Old Jul 23, 2006 | 05:21 PM
khmboostedeh2's Avatar
If you're doing a fresh bottom up motor build you might want to stop now and realize that cutting corners isnt going to get you anywhere. Do it right the first time and never worry about it again.
If theres rust on the cylinder walls a slight hone might not be enough to get rid of it. Have the machine shop do it, bring them your pistons and let them know the maximum piston to wall clearance you can have. They'll be able to tell you if you can get by with just honing the block or if it needs to be bored.
Old Jul 23, 2006 | 05:25 PM
Default Re: DIY hone/deglaze of cylinders? (Jeterkm02)
well i was trying to learn how to do all this myself...but either way...
Old Jul 23, 2006 | 08:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote">well i was trying to learn how to do all this myself...but either way...</TD></TR></TABLE>
I dont blame you, I have that mentality as well, But you're dealing with a fine line of doing it right and doing it wrong when it comes to clearances.
Old Jul 23, 2006 | 08:54 PM
ok so either way...
does anyone have info on how to do this? eventually i want to do a motor myself completly and not have any work farmed out...so help a brotha out lol
djsharmz
Mar 10, 2011 06:25 AM
DulinDragons
Jul 3, 2009 09:00 AM
GsrIntegra789
28
Feb 7, 2008 08:02 AM
Adriano
Oct 10, 2002 10:21 PM
