Rear Mount
Old Jul 23, 2006 | 03:37 PM
crxpwr1's Avatar
Default Rear Mount
How in da hell u get it off I was out there for about an hour and couldnt get to it?
Old Jul 23, 2006 | 03:43 PM
crxpwr1's Avatar
Default Re: Rear Mount (crxpwr1)
I mean the rear bolt in the rear mount.....I tryed everything going from under straight threw it what else?
Old Jul 23, 2006 | 03:49 PM
Suck my DX's Avatar
its a lil tricky...i used a 3/8 in socket with an adjustable neck...first i had to slide in the two pieces one by one and once they were on the bolt just stuck an extension in there and twisted it out
Old Jul 23, 2006 | 03:56 PM
crxpwr1's Avatar
Default Re: Rear Mount (Suck my DX)
damn I tryed my adjustable neck but it wouldnt fit haha that sucks
Old Jul 23, 2006 | 04:31 PM
dr_latino999's Avatar
I had to remove the rear crossmember, which also means you have to disconnect the front suspension and the steering column. If you're good at it, within 90 minutes with hand tools its coming off.
Old Jul 23, 2006 | 04:34 PM
crxpwr1's Avatar
Default Re: Rear Mount (dr_latino999)
damn that sucks ^^ Ima try to get it off without doing that
Old Jul 23, 2006 | 04:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">damn that sucks ^^ Ima try to get it off without doing that</TD></TR></TABLE> Well it is possible to just lower the rear crossmember, but it's still a pain in the nether regions.
Old Jul 23, 2006 | 05:11 PM
Suck my DX's Avatar
damn that sucks...luckily mine had just enough space for me to slip in the socket...weird cuz i crashed it and it pushed everything back a lil bit and i still had enough room...did you try fitting the socket on the bolt with ur hand before trying it with the wrench?
Old Jul 23, 2006 | 05:16 PM
Crx Jimmy's Avatar
If I remeber correctly the mount is held on by 3 bolts take the front 2 out then hit the mount with a hammer and it will pivot on the back bolt and when the mount is a little sideways its way easier to get a socket with the wobble extension on it and get it off, good luck
Old Jul 23, 2006 | 05:24 PM
Loserkidwac's Avatar
Default Re: Rear Mount (Crx Jimmy)
I just used some extensions and a swivil(however its spelled) on a rtachet and got to it fairly easy
Old Jul 23, 2006 | 06:12 PM
crxpwr1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">If I remeber correctly the mount is held on by 3 bolts take the front 2 out then hit the mount with a hammer and it will pivot on the back bolt and when the mount is a little sideways its way easier to get a socket with the wobble extension on it and get it off, good luck </TD></TR></TABLE>
would that not strip it but yea I might try it but to answer suck my dx I did try to see if it fit first just the wrench was to big so have to find a different wrench some where
Old Jul 23, 2006 | 06:25 PM
Suck my DX's Avatar
dont u have any extensions?
Old Jul 23, 2006 | 06:27 PM
crxpwr1's Avatar
yep but I cant get to it....but I think I know what your saying put the socket on the extension and get a wrench and turn it from top am I correct?
civiced1
Jan 4, 2012 04:17 PM
8VEYBEYB
12
Aug 25, 2009 11:01 AM
MidShipCivic
Sep 26, 2007 04:28 PM
ScottEK
Mar 20, 2003 11:49 AM
SOUTHCREX
Feb 11, 2003 03:33 AM
