Cusco LSD Help
Hey guys i bought a Cusco LSD from a Guy on Honda-Tech
he said it was for B16/GSR Trannies, so i bought the LSD figuring it would fit my SI...now i go to install my ring gear from my Open Diff..and Inside Diameter of the LSD is too small to fit this LSD....
Cusco's website says
part# LSD328B15 is for Civic/Integra B16A/B18C 93.5-up i assume
is there any differences in the GSR/Type R ring? other than Ratios...and if so can i buy a ring gear to fit this LSD with the same Gear Ratio that my SI has now?
From: gravity rides everything...everything will fall, se GA/ne FL
i gathered you have a gsr/itr lsd and not a "b16/gsr". since you have a '00 si and the i.d. on your stock ring is too small for the cusco, then you need a gsr/itr 4.40 ring.
