best throttle body for EF
i would get another stock type-r or find a dirt cheap b16 piece and have it bored out to the stock type-r specs..
http://maxbore.com/
http://maxbore.com/
Attention all, I need to replace my throttle body because I think the butterfly valve spring is worn out, it like to stick at 3000 rpm when I am in low gears shifting around town, have to jab the throttle to get it to settle down. My mechanic looked at it and that was his conclusion. Adjusting the idle does not make the problem go away..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gyrmaersk »</TD></TR><TR><TD CLASS="quote">Attention all, I need to replace my throttle body because I think the butterfly valve spring is worn out, it like to stick at 3000 rpm when I am in low gears shifting around town, have to jab the throttle to get it to settle down. My mechanic looked at it and that was his conclusion. Adjusting the idle does not make the problem go away..</TD></TR></TABLE>
Did your mechanic look at the throttle cable? It will have the same effect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bakerboy4679 »</TD></TR><TR><TD CLASS="quote">Why don't you just replace the spring?
sounds like a good idea to me and a lot cheaper
</TD></TR></TABLE>sounds like a good idea to me and a lot cheaper
****, I didn't know the spring was available as a single part. Where can I find one?
BTW people, it used to be cable tension, but some fiddling and a zip tie later, I eliminated that, I know because I open the hood and tug on the cable, turn the butterfly valve by hand, and it will stick with plenty of cable slack. So I'm thinking it must be the spring.
