help wiring indiglos
My indiglos should be in at the end of this week for my '92 integra. I already took out the vents and what not , so that should save me some time. Anyway , i've heard that you are suppose wire indiglos to your dimmers, i was looking at the wires running into the dimmer switch, there is a black one and two red ones. Which wire do I need to splice or cut , and connect to the indiglo wires? thanks a lot everyone.
Use a multimeter and figure it out yourself! Worked for me!
And actually, I'd actually wished I never put those in. Anyone got a JDM DA cluster for sale?
[Modified by teg92, 6:57 PM 4/22/2002]
I have a 98 Teg, and I have installed indiglos myself. With mine, came 2 wires (a red and a black) so I spliced both and connected. It's a simple process. I dunno about your Teg though, but it's probably similar.
i'm not sure how far the wiring is on the clock on g2 tegs, but on my g3 teg, i wired it up to my clock. just ground it to black, and i forget which wire is the dimmer for the clock when the light is on, but you only have like 3 other choices, so just use a multimeter or test light and find out, took me like 5 minutes to do... hope that helps
-brian
-brian
justaskgrandpa
Apr 3, 2016 10:34 AM
