94 ex hard to start after its warm( already searches but my problem seems different)
Old Jul 23, 2006 | 01:39 PM
djfob's Avatar
Default 94 ex hard to start after its warm( already searches but my problem seems different)
When the car is cold or left over night its easy to start but seems a bit weaker than usual. After its warmed up it won't fire up, it cranks slow to a point where it won't crank at all. If I let it sit for 10 minutes it'll fire up but if i turn it off right away and try again D'd have to wait about 10 minues again. It seems like the battery is weak but it puts out 12v and when it does run the alternator puts out 14v. Also when it won't fire the radio,cluster, clock don't work either and idles like crap like it's gonna die. I've cleaned the tranny ground, thermostat and valve cover ground also. I've also tried 2 other batteries, I'm stumped.
Modified by djfob at 5:16 PM 7/23/2006
Old Jul 24, 2006 | 10:13 AM
djfob's Avatar
bump
Old Jul 24, 2006 | 10:58 AM
prison_snitch's Avatar
its probly your main relat by your left foot. when you turn the car on do you hear the fuel pump go WHIRRRRRR? if not then its your main relay
Old Jul 24, 2006 | 05:55 PM
djfob's Avatar
Default Re: (prison_snitch)
yeah I hear the pump prime
Old Jul 24, 2006 | 07:16 PM
brockscivic's Avatar
Default Re: (djfob)
i would look for a corroded starter connection or alternator connection...and just make sure everything is tight...such as the two wires that go into the fuse box
Old Jul 24, 2006 | 09:26 PM
djfob's Avatar
Default Re: (brockscivic)
I will look into that, last time I checked everything looked good.
Old Jul 25, 2006 | 09:21 AM
Default Re: (djfob)
i mean it might not be those but that would explain why it seems like power flow is restricted
Old Jul 25, 2006 | 09:49 AM
gents97civ's Avatar
check the rotor and cap for moisture or corrosion as well. Or possibly the ignitor could be going.
fog raw
Jan 28, 2012 06:52 AM
msilvias15
Jun 16, 2010 03:41 AM
woodwardba0526
Honda Civic (2001 - 2005)
Apr 13, 2010 01:31 PM
djryan
Jul 13, 2007 03:37 AM
WRTEG
Nov 23, 2004 12:05 PM
