cx trans
Old Jul 23, 2006 | 11:54 AM
dcwoodard's Avatar
Default cx trans
need to know if a cx trans will work with a d16z6 or any 16 valve engine? someone said the splines were different on the input shaft. If that is so then I was wondering if you could use the flywheel off the cx on the 16 valve??
Old Jul 23, 2006 | 12:03 PM
RaYnE's Avatar
yes. d series parts are interchangable.
Old Jul 23, 2006 | 01:24 PM
dcwoodard's Avatar
Default Re: (RaYnE)
I heard the cx is like 20 splines and the others are 21 or something like that.
Old Jul 23, 2006 | 01:36 PM
si0385.'s Avatar
not 100% on this one but i thought the only 21 spline d-series trans was the 88 crx si trans that also used a 200 mm clutch rather than a 220mm clutch...
all i know for sure is if you use a cx trans with a z6 you will be verry disapointed in the gearing, its way too high
Old Jul 23, 2006 | 01:46 PM
big-cat's Avatar
yes indeed i have a cx and still have the stock tranny and it deff blows my left nut. cant wait till i have boost.then it will come in handy.
Old Jul 23, 2006 | 02:09 PM
tha_badguy's Avatar
no matter if u have boost or not the cx tranny still sucks *****
Gixx312
Aug 13, 2009 12:50 PM
Not_So_JDM
Aug 28, 2006 04:08 AM
civicracer1993
23
Nov 30, 2002 10:11 AM
SmoothVTEC
Oct 15, 2001 05:20 PM
