Bad Vss = Car running rich?
Old Jul 23, 2006 | 10:28 AM
blackdc's Avatar
Default Bad Vss = Car running rich?
My VSS isnt working, and my check engine light for the VSS comes on from time to time. Would this cause my car to be running very rich?
Thanks in advance
Old Jul 23, 2006 | 10:30 AM
bmoua's Avatar
Default Re: Bad Vss = Car running rich? (blackdc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc &raquo;</TD></TR><TR><TD CLASS="quote">My VSS isnt working, and my check engine light for the VSS comes on from time to time. Would this cause my car to be running very rich?
Thanks in advance</TD></TR></TABLE>
its running rich but its also something else too...some one correct me if im wrong....
Old Jul 23, 2006 | 10:35 AM
md88hfcrx's Avatar
Default Re: Bad Vss = Car running rich? (bmoua)
vss is speed sensor, dont think it would cause it to run rich.
only way is if the ecu automatically retards timing b/c there is a
CEL. thus causing it to run rich. but does the ecu do this on a vss code?
Old Jul 23, 2006 | 10:37 AM
krisjk2's Avatar
Default Re: Bad Vss = Car running rich? (md88hfcrx)
no. my vss went out and it ran the same way as it did before, just the speedo jumped a lot.
Old Jul 23, 2006 | 10:46 AM
ghost_ryder35's Avatar
A VSS will not MAKE your car run rich.
Old Jul 23, 2006 | 11:24 AM
hondaboy4life's Avatar
Default Re: Bad Vss = Car running rich? (ghost_ryder35)
a bad vss can cause vtec not to work tho.
Old Jul 23, 2006 | 01:06 PM
LCheung's Avatar
Default Re: Bad Vss = Car running rich? (hondaboy4life)
How can a VSS cause VTEC not to work? Since when was VTEC dependent on vehicle speed? VTEC activation is RPM dependent, not vehicle speed dependent. The ECU doesn't get it's RPM signal from the VSS. That whole statement is just confusing.
What makes you think your car is running rich? What's been done to it? How rich is rich here? Are you sure it's too rich? Did you have a wideband on it?
Come on guys... seriously... what kind of help do you expect to get here if you haven't made sense of it yourself yet. And people trying to help... I have no idea... I'm speechless... just wow.
-Leon
Old Jul 23, 2006 | 01:10 PM
jdmjaser's Avatar
Default Re: Bad Vss = Car running rich? (LCheung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LCheung &raquo;</TD></TR><TR><TD CLASS="quote">How can a VSS cause VTEC not to work? Since when was VTEC dependent on vehicle speed? VTEC activation is RPM dependent, not vehicle speed dependent. The ECU doesn't get it's RPM signal from the VSS. That whole statement is just confusing.
-Leon
WORD to that....my vss was not working for 7 months and i pop vtec all the time...
Old Jul 23, 2006 | 09:54 PM
Default Re: Bad Vss = Car running rich? (jdmjaser)
thats funky, cuz when my vss stopped working, so did my vtec, i have heard of it being like that b4. But if its wrong, then sorry for the false info.
Old Jul 23, 2006 | 10:01 PM
JDM-EJ1's Avatar
It wouldn't cause you to run rich.
Old Jul 23, 2006 | 10:30 PM
blackdc's Avatar
Well, the car smells very rich. Its a stock d15 with stock ecu, it only has a dc header and intake. It has no catylitic converter either. The speedo doesnt work, but the vss cel only comes on when I downshift and coast.
Old Jul 24, 2006 | 07:59 AM
Morning Call's Avatar
my vss dont work i dont throw a cel for it.
but as far as i know vtec is dependant on these things:
throttle/speed/oil pressure
if your not wot, ur not vtecing
if u dont have oil or pressure, ur not vtecing
if your driving faster then 25mph, ur not vtecing
Old Jul 24, 2006 | 08:03 AM
doublejz's Avatar
-Leon
yes vtec is related to speed.... also it throws a CEL which most CELs will disable vtec.. doesnt have to be in limp mode to not have vtec..
anyway.. VSS wont cause your car to run rich
Archidictus's Avatar
Unceasing Measure
Default Re: (Morning Call)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call &raquo;</TD></TR><TR><TD CLASS="quote">my vss dont work i dont throw a cel for it.
correct me if im wrong</TD></TR></TABLE>
You're 100% wrong. Die in a fire.
Old Jul 24, 2006 | 08:07 AM
SkoundrelUSA's Avatar
cute little bastard
My friend had a bad VSS and VTEC was definitly not engaging.
From what I have read in the past, VTEC won't engage unless the car is moving. And if the VSS is broken, the ECU thinks its sitting still so it won't engage. This is just from what I have read. I do not know for a fact if this is the reasoning.
Old Jul 24, 2006 | 08:43 AM
bsixteen's Avatar
think about what your typing before you do it. you can be 1/2 throttle or 3/4 throttle and still get to the rpm necessary for vtec. and how the hell are you going to be in vtec driving slower than 25mph?
slowem1si
Apr 4, 2006 03:09 PM
tub_sephiroth
Sep 17, 2004 10:17 PM
kaj
Jun 2, 2004 08:18 AM
sewage7
13
Apr 21, 2003 08:37 AM
