What throttle body to use with Euro-R IM?
Old Jul 23, 2006 | 08:05 AM
sivikvtec's Avatar
Default What throttle body to use with Euro-R IM?
Can you use an Integra Type-R throttle body on this intake manifold? My car is OBD I so will that affect anything?
Old Jul 23, 2006 | 08:31 AM
Missing Gears's Avatar
Default Re: What throttle body to use with Euro-R IM? (sivikvtec)
i have always used the b16 tb from the 98 civic si.
Old Jul 23, 2006 | 08:38 AM
sivikvtec's Avatar
Default Re: What throttle body to use with Euro-R IM? (Missing Gears)
So the tps sensor and everything is ok? Thanks for the help
Old Jul 23, 2006 | 09:23 AM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivikvtec &raquo;</TD></TR><TR><TD CLASS="quote">So the tps sensor and everything is ok? Thanks for the help </TD></TR></TABLE>
Yeap. You can also plug the map sensor on the TB or just rewire it off the firewall and us the one on top of the TB for a cleaner install
Old Dec 9, 2006 | 03:36 PM
precisionelite's Avatar
Default Re: What throttle body to use with Euro-R IM? (md23vtec)
I'm looking into this as well. I'm thinking either a skunk2 68 or 70mm. Does taper really make that big of a difference?
Old Dec 9, 2006 | 06:58 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">i have always used the b16 tb from the 98 civic si.</TD></TR></TABLE>
what size is the b16?
Old Dec 9, 2006 | 07:19 PM
94vtirozguy's Avatar
why not get the TB that was designed with the IM
Old Dec 9, 2006 | 07:59 PM
SHhh__VTEC's Avatar
I used Service RPM 68mm throttle body with my old euro r IM
It worked good for me.
Old Dec 9, 2006 | 08:22 PM
sivikvtec's Avatar
Default Re: (94vtirozguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy &raquo;</TD></TR><TR><TD CLASS="quote">why not get the TB that was designed with the IM</TD></TR></TABLE>
because its impossible to find/expensive.
Old Dec 9, 2006 | 10:36 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (sivikvtec)
ITR is thre best way to go. Exact replica of the euro-R tb and no fitment issues.(2mm bigger than and H22 TB I beleive)
Old Dec 9, 2006 | 10:43 PM
98vtec's Avatar
moderator emeritus
Default Re: (cb7-R)
can we please post dimensions of these TB's?
my s2k throttle is 66mm and tapers to a 62mm throttle. The stock h22 throttle is 62mm and tapers to a 60mm throttle.
Old Dec 10, 2006 | 08:21 AM
Default Re: (B.Rabbit)
I think i'm gonna go with the Skunk2 68. It seems that other TB's I've seen on here have a problem with sticking. I'm sure not everyone does, but i havn't heard anything bad about the Skunk 2. Would 68mm be the best size for my setup?
Here's my setup:
H22a4
AEM CAI
Euro-R Manifold (To Be Installed)
Type S cams (To Be Installed)
Type One Racing Header (2.36'' collector)
Test Pipe (2.25'')
Thermal R&D Exhaust (2.25'')
Modified by precisionelite at 12:35 PM 12/10/2006
Modified by precisionelite at 12:36 PM 12/10/2006
Modified by precisionelite at 7:49 PM 12/10/2006
Old Dec 10, 2006 | 09:26 AM
redludeshohio's Avatar
Default Re: (precisionelite)
https://honda-tech.com/zerothread?id=1566202
DO NOT get a Skunk2. BDLs do not have this problem, check out the latest Honda Tuning for info on them.
Skunk2 has had my throttle body for 4 months now and hasn't even called me back about it.
I've called numerous times, sent complaints etc.
PLEASE get BDL!!!!!
Old Dec 10, 2006 | 10:55 AM
Default Re: (redludeshohio)
Thanks for the advice!
BDL 68-66 TB purchased
Old Dec 10, 2006 | 02:22 PM
Propulsion's Avatar
will the Base h22 TB work?
Old Dec 10, 2006 | 03:48 PM
Default Re: (Propulsion)
I've heard that there are adaptors you can make for it. I just wanted to go w/a bigger TB since i'm going with a euro-r mani and type s cams. Seems like the next logical step to me.
Old Dec 12, 2006 | 08:13 AM
SiRek4
Guest
Posts: n/a
theres no such thing as a 98 civic si
Old Dec 12, 2006 | 09:08 AM
sivikvtec's Avatar
Default Re: What throttle body to use with Euro-R IM? (SiRek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRek4 &raquo;</TD></TR><TR><TD CLASS="quote">
theres no such thing as a 98 civic si</TD></TR></TABLE>
actually there is.....In Canada
and it has a D16
but i'm sure he meant 99 Si
Old Dec 14, 2006 | 08:58 PM
Propulsion's Avatar
alright, I just ordered a 65mm TB made for the ITR. This should work if I swap all the sensors over from my base H22 TB correct?
Old Dec 14, 2006 | 09:29 PM
98vtec's Avatar
moderator emeritus
Default Re: What throttle body to use with Euro-R IM? (Propulsion)
yes, just be sure to calibrate the TPS.
Old Dec 15, 2006 | 06:23 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Propulsion &raquo;</TD></TR><TR><TD CLASS="quote">will the Base h22 TB work?</TD></TR></TABLE>
it leave a large vacuum leak from the ports for the fast idle valve which the euro-r does not have.
Old Dec 15, 2006 | 07:50 AM
Default Re: What throttle body to use with Euro-R IM? (B.Rabbit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit &raquo;</TD></TR><TR><TD CLASS="quote">yes, just be sure to calibrate the TPS.</TD></TR></TABLE>
Do I have to calibrate the TPS with an aftermarket TB? (BDL 68/66)
-Greg P
Old Dec 15, 2006 | 07:54 AM
98vtec's Avatar
moderator emeritus
Default Re: What throttle body to use with Euro-R IM? (precisionelite)
if you have to remove the TPS from your stock TB and place it onto the aftermarket one, yes.
All you need is a multimeter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precisionelite &raquo;</TD></TR><TR><TD CLASS="quote">Do I have to calibrate the TPS with an aftermarket TB? (BDL 68/66)
-Greg P</TD></TR></TABLE>
Old Dec 15, 2006 | 08:57 AM
roller3804's Avatar
how would you calibrate it with a multimeter?
vinuneuro's Avatar
What's the diameter of the EuroR mani inlet?
