Alternator Install?
Old Jul 23, 2006 | 06:05 AM
londonsupra's Avatar
Default Alternator Install?
Can someone add the steps to the accord FAQ regarding an alternator install on a 4thgen with AC?
Thanks
Old Jul 23, 2006 | 11:33 AM
hondadude's Avatar
Default Re: Alternator Install? (londonsupra)
Pretty straight foward job. remove the P/S pump 2 bolts, lay it off to the drivers side, leave the hoses hooked up. Disconnect the neg batt terminal. unplug the ALT, and remove the big batt lead on the ALT. Then a 14 mm bolt on the top of the ALT and a 12mm nut on the bottom. slip out the lower tensioning bolt; wiggle the ALT and pull up. Taaa DAAAA
Kajun
May 27, 2019 09:36 AM
Simmerman
Aug 30, 2007 05:20 PM
ch4nq
18
Jul 26, 2004 01:59 AM
95 GaNgStA AcCoRd
Oct 14, 2003 08:12 AM
