Safe to lower car on 17x7.5 wheels?
Old Apr 22, 2002 | 12:14 PM
JoshRambo's Avatar
Default Safe to lower car on 17x7.5 wheels?
Just wondering idf anyone knwos if it would be a problem if i was to lower my car say .75". I am currently useing 17"x7.5" Volk TE-37's. To me it looks like i will have some rubbbing if i lower the car at all casue the wheel sticks out a bit.
Old Apr 22, 2002 | 12:32 PM
htowncivicEX's Avatar
Default Re: Safe to lower car on 17x7.5 wheels? (Gravity)
If rubbing does occur, you can always set the wheel to some slight negative camber to fix the problem. Then you can adjust the toe accordingly so that the negative camber won't wear out your tires unevenly.
This is what I did my car earlier today. One of my tires (driver's rear) was rubbing like crazy and the other 3 were fine even though they all had a 1 finger gap. I even rolled the fender and it still rubbed! So I finally took it in for an alignment today and discovered that the wheel was rubbing because it had too much positive camber so it was slightly sticking out of the fenderwell. I had the mechanic adjust it to about -1.7 degees camber so now it tucks slightly into the fenderwell like all of the other wheels. No more rubbing
Old Apr 22, 2002 | 12:47 PM
yoshi234's Avatar
I shoot brides
i got the same wheels and they rub occasionally in the rear. i'm gonna roll the fenders and also pull the fenders out slightly for even more clearance.
Old Apr 22, 2002 | 02:22 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: Safe to lower car on 17x7.5 wheels? (yoshi234)
this is on DC2 R I assume? What is the offset your guys using on these 7.5" width rims?
Old Apr 22, 2002 | 02:39 PM
yoshi234's Avatar
I shoot brides
Default Re: Safe to lower car on 17x7.5 wheels? (frank@b16a.com)
correct assumption
+40mm offset
Old Apr 22, 2002 | 03:51 PM
JoshRambo's Avatar
+40mm offset
yup
is your car lowered Yoshi? i know i tlked to you the other day about the wheels and all.
also what kind of places roll the fenders. i would assume good shop would be able to do it. i don't want to use the baseball bat trick on mine.
i got an im form another guy saying his car is lowered about 1.5" and is fine.
Old Apr 22, 2002 | 04:35 PM
Banned
what size tires? any rubbing on the front?
Old Apr 22, 2002 | 04:39 PM
yoshi234's Avatar
I shoot brides
seems if you have 205/40 it won't rub, but I got 205/45. taller tyre for a little extra protection against bending the rim on potholes
currently, rear tyres are rubbing but not the front (at least not in a straight line). Not sure if it'd rub during hard cornering situations.
yshi - who'll be using 205/40 for the track
slvrcvc93
19
Apr 30, 2008 11:52 AM
kevinm1981
Feb 8, 2008 05:04 AM
chino369
Suspension & Brakes
Apr 18, 2007 02:53 PM
mangop
Aug 22, 2004 09:25 PM
Infinity_Racer
Feb 18, 2004 10:43 AM
