Wht is my ecu out of :S
Old Jul 23, 2006 | 03:37 AM
Chris_V-TEC's Avatar
Default Wht is my ecu out of :S
didnt where to put this thread but anyways, jst purchased my b81c engine, hoping to rebuild for turbo spec, but cant figure out wht my ecu is out of or wht it is ie, p73, 72 etc. these are the number tht are on the casing: 37820-p9k-e11
361694-7z18
EJ1, thanks in advance guys.
Old Jul 24, 2006 | 12:32 AM
mtber's Avatar
Default Re: Wht is my ecu out of :S (Chris_V-TECH)
The ecu is for a civic 1.8 VTi B18C4
It is obd2 if I remember correctly.
You will want to go with a obd1 ecu and a obd2 to obd1 conversion harness depending on what year your car is.
Read over: http://www.phearable.net/tech/....html
Old Jul 24, 2006 | 09:29 AM
Default Re: Wht is my ecu out of :S (mtber)
Ok thanks man the helped , wht ecu would you recomend i run for a mild turbo setup, p73? car is a 97 ek civic, 1.5 v-tec at the mo, uk spec also if tht makes any differance. thanks again dude
frostwhite_92
May 28, 2013 11:29 AM
Pimpsherm2009
Jan 13, 2010 06:05 PM
Joeski99Si
Sep 4, 2008 10:18 AM
eater_eg6
Dec 12, 2005 12:54 AM
4drb18ek
Mar 1, 2003 07:42 AM
