tech question..
Old Jul 22, 2006 | 07:35 PM
purestreetracer's Avatar
Default tech question..
i have a spd sensor code but i replaced the speed sensor with new one...and still get a check engine light(speed sensor code). the speedometer and odometer guages arent working so im thinking it may be the guage cluster....? but im not sure if that would throw a check engine light(speed sensor code)..would it? i checked the wiring connecting to the ecu and its okay... anyone with expierence with this that has info would be greatly appreciated.
-if read and have no answers please bump thanks
Modified by purestreetracer at 9:51 PM 7/22/2006
Old Jul 24, 2006 | 12:39 AM
bump
Old Jul 24, 2006 | 06:15 AM
miahmouse's Avatar
Default Re: tech question.. (purestreetracer)
Since you've already replaced the sensor I'd re-check the wiring. Continuity from the sensor plug to the ECU. If I remember correctly, the wires go from VSS to ECU to Cluster. The cluster not working won't trip a VSS code, only VSS to ECU.
Old Jul 26, 2006 | 04:48 PM
Default Re: tech question.. (miahmouse)
thanks for the answer...i will check it out..thats the only thing i havnt checked yet..
gorillapno
May 26, 2008 09:38 PM
petty$rep
Oct 24, 2006 01:57 PM
JDMtype Eg6
Aug 10, 2005 02:58 AM
BoRiCuA
Nov 23, 2004 06:49 PM
89civicdx
Oct 11, 2002 04:35 PM
