Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
ENGINE LIGHT ON!
Old Jul 22, 2006 | 07:28 PM
Anthony1's Avatar
Default ENGINE LIGHT ON!
I removed the Intake sensor from the intake i and the engine light went on i put it back on and the light is still on why is that will it go off? HELP! i got a 06 SI
Old Jul 22, 2006 | 07:39 PM
Miracle's Avatar
Default Re: ENGINE LIGHT ON! (Anthony1)
Not to worry, if you replaced the sensor, the ECU will reset itself if nothing is truly wrong after a couple engine cycles, (Warm up and cool down)
Happened to me, but You dont have to worry.
Old Jul 22, 2006 | 08:02 PM
Anthony1's Avatar
Default Re: ENGINE LIGHT ON! (Red_EM2)
THANKS Man...
Old Jul 23, 2006 | 12:45 PM
-Gambit-'s Avatar
you could wait but if its really bothering you just reset your ecu and it will go away.
Old Jul 23, 2006 | 08:14 PM
Demonis's Avatar
yeah ^^^ battery unhook for 10 mins should do it, i dont think it takes longer. (BTW - is there an actual reset button or fuse for the ECU? just a thought)
Old Jul 24, 2006 | 03:36 AM
Yablargo's Avatar
Default Re: (Demonis)
Im sure theres an ECU fuse, but just pull the neg terminal and pump the brakes a few times, and voila
Old Jul 24, 2006 | 04:40 PM
. L i z's Avatar
Default Re: (Yablargo)
you have to reset it for it to go off
Old Jul 25, 2006 | 07:04 PM
sweetdill's Avatar
Default Re: (. L i z)
if you pull the ecu fuse, you won't have to reset your stereo stations.
boostedgsreg
Engine Management and Tuning
Jul 14, 2008 02:17 PM
5thgenbb6
Jul 14, 2007 08:33 PM
9civic8
Apr 2, 2004 08:51 AM
CleanLIttleLude
Jun 13, 2003 12:09 PM
inzane
Mar 18, 2002 02:11 PM
