92 acura Integra not running right
Old Jul 22, 2006 | 06:54 PM
black_integra's Avatar
Default 92 acura Integra not running right (updated)
I bount My 92 integ three days ago. When in drive it kicks and dies on me. I had three amps in the car but i took them out because i thought it was the reason. My Kenwood Cd player keeps turning off and on when i turn it up past 29. It still shuts off and on, my lights don't dim or nothing. I think it is bad wiring. Have any of you have the same prob. oh the timing belt was changed I was told. It seems it is idoled low. What should the the RPM's be at?
Modified by black_integra at 8:37 AM 7/26/2006
Old Jul 23, 2006 | 05:31 PM
Default Re: 92 acura Integra not running right (black_integra)
so nobody has any ideas
Old Jul 23, 2006 | 05:39 PM
mike9571's Avatar
Since you changed the timing belt, are you sure your timing is correct. That would cause it to run bad
Old Jul 23, 2006 | 05:40 PM
mike9571's Avatar
Default Re: 92 acura Integra not running right (mike9571)
O nevermind i thought you said you changed it
Old Jul 23, 2006 | 05:43 PM
jared99's Avatar
How low is the idle? The idle screw might need to be adjusted if the prior owner was playing with it. If you turn the a/c off, and rev it slightly, to bout 1200rpm, then put it in drive, does it work without stalling? Your iacv might also have a problem.
Old Jul 24, 2006 | 02:17 AM
dannylDAsport's Avatar
maybe u need a tune-up
Old Jul 24, 2006 | 09:15 AM
DB1_559's Avatar
bump mines backfiring
Old Jul 26, 2006 | 07:37 AM
well it only dies at night time when i turn my lights on it goes for a while then dies on me when my rpms go down
Old Jul 26, 2006 | 08:18 AM
Noemotion_91DA's Avatar
I would pull the alternator off and have it tested. The next thing is to check your fuel fitler.
StevenGunn
Nov 21, 2010 03:23 PM
klp852003
Aug 21, 2007 08:49 AM
llevity
Jul 12, 2005 02:39 PM
ebpda9
Apr 3, 2005 04:30 PM
