NITROUS HELP!!!!
Old Jul 22, 2006 | 05:18 PM
lCHaCHeel's Avatar
Default NITROUS HELP!!!!
well i got a dry nitrous kit and im done installing it now i turn the car on but dont crank it on, i opened the bottle and heard the nitrous bleed afterwards i flipped my switch on and it started spraying as soon as it flipped on... is it suppose to spray as soon as i flip the switch im under the impression that it only sprays at full throttle so when im smashing on the gas??? can anyone help me please its ok if its something stupid u guys can flame i just need some info... i have a 90 crx si with a b18b headers full cat back intake obd-0 please guys
Old Jul 22, 2006 | 05:22 PM
crxpwr1's Avatar
Default Re: NITROUS HELP!!!! (lCHaCHeel)
why didnt you turbo insted of spray????
Old Jul 22, 2006 | 05:32 PM
lCHaCHeel's Avatar
Default Re: NITROUS HELP!!!! (crxpwr1)
**** i wish but unfortunately im on a budget
Old Jul 22, 2006 | 06:11 PM
y-49's Avatar
what kind of kit do u have. the only kit i am aware of that works this way is the zex kit, and u can buy a module to hook to any kit. but did u have wires that go to the tps. if u dont then no it will spray when u hit the switch.
Old Jul 22, 2006 | 06:31 PM
lCHaCHeel's Avatar
Default Re: (yellow rex)
i got a ZEX dry nitrous kit it has a white wire that i ran to the tps but im not sure which wire on the tps im spose to splice to however i tried all the 3 wires on the tps and the only 1 that seem to work was the white one on the tps... is it the white one???
Old Jul 22, 2006 | 07:07 PM
Tippyman's Avatar
Default Re: (lCHaCHeel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lCHaCHeel &raquo;</TD></TR><TR><TD CLASS="quote">i got a ZEX dry nitrous kit it has a white wire that i ran to the tps but im not sure which wire on the tps im spose to splice to however i tried all the 3 wires on the tps and the only 1 that seem to work was the white one on the tps... is it the white one??? </TD></TR></TABLE>
I don't tink ur supposed to splice into a TPS wire, I think it has a micr-switch you mount on the Throttle body.
Old Jul 22, 2006 | 07:27 PM
lCHaCHeel's Avatar
Default Re: (Tippyman)
pm
Old Jul 22, 2006 | 09:04 PM
JohnnieChimpo's Avatar
No it should not flow as soon as you arm it.
I'm not sure of the TPS colors but I'm betting you hooked it to the wrong one.
It should only feed under full throttle.
Google ZEX PDF instrutions and see if you can find the correct wiring.
Old Jul 22, 2006 | 09:14 PM
Tippyman's Avatar
Default Re: (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Google ZEX PDF instrutions and see if you can find the correct wiring.</TD></TR></TABLE>
Lol, we already did that...
lCHaCHeel's Avatar
i hope thats all thats wrong ill google and ill come back in the morning see if any1 has some more ideas for me thanks a l;ot for your help
Old Jul 22, 2006 | 09:16 PM
driveahonda's Avatar
GO to the zex website and follow the install instructions. And do not turn on your car if you just sprayed into your intake with the car off.
It is tough typing drunk.
So im bored and i fount this for you.. http://www.zex.com/Base/Instructions/ZEX109.pdf
Old Jul 23, 2006 | 08:01 AM
lCHaCHeel's Avatar
Default Re: (driveahonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda &raquo;</TD></TR><TR><TD CLASS="quote">GO to the zex website and follow the install instructions. And do not turn on your car if you just sprayed into your intake with the car off.
why cant i turn my car on??
Old Jul 23, 2006 | 02:18 PM
Your engine will fill up with nitrous. Once you start the engine the first spark will be a really lean (all NO2) and will hurt stuff, if it'll start at all (too lean). If it was a wet system it would be even worse as it would explode all the fuel and NO2.
Just turn the bottle off and see if the 'noid clicks when you want it to.
Turning the nitrous on at idle (while running) would be bad too.
Modified by JohnnieChimpo at 9:22 PM 7/24/2006
Old Jul 23, 2006 | 06:54 PM
Garage 808 Hatch's Avatar
its the center wire on the tps. make sure you go through the part where the nitrous kit learns your tps signal. you have to do a few things with the key on, and the black button on the box. its all in the install. if you didnt teach it wide open throttle, then its probably that
Old Jul 24, 2006 | 05:42 PM
lCHaCHeel's Avatar
Default Re: (Garage 808 Hatch)
i dont have a black button on my zex brain...
however i solved the problem... thanxs for the replies but it turns out that i had the wrong wire on the tps and when i rewired it corredt it still didnt spray but my throttle body wasnt opening all the way so of course it wont spray if its not WOT so i just adjusted my throttle cable and BAM!!! fixed but it is fixed now so thanxs again
BIG T
Feb 26, 2008 12:45 PM
lCHaCHeel
Jul 24, 2006 05:46 PM
BlackEG6
18
Jan 22, 2005 01:12 AM
TurboT
Nov 9, 2003 04:50 PM
