oil filter intallation.
Old Jul 22, 2006 | 03:48 PM
Jmumblez2001's Avatar
Default oil filter intallation.
i don't wanna seem like a dumbass but i feel i should ask. when installing the oil filter do ya just screw it on and torque it or is there a special rule ya gotta follow. i wanna do it right and move on with life, if you have installed one before gimme your feedback.
Old Jul 22, 2006 | 03:52 PM
hondadude's Avatar
Default Re: oil filter intallation. (Jmumblez2001)
Make sure the old seal came off with the old filter; the new one should turn 7/8 of a turn past where the seal makes contact with the filter base area.
Myself, I crank them on as hard as I can by hand.
Old Jul 22, 2006 | 05:46 PM
standbackimapro's Avatar
Unscrew the old one, Make sure the gasket isnt stuck to the filter plate
Screw on the New filter like a quarter turn after the filter comes in contact with the filter plate
And dont feel dumb, Its always good to ask questions, thats how people learn..
Old Jul 22, 2006 | 06:41 PM
ricebike's Avatar
to add:
put some oil into the center of the filter & pre-charge the filter media w/ some fresh oil... based on the filter's orientation, I usually fill it up to 1/2 quart in other makes (cause they mount it so it'll be full of oil i.e. some mazdas/fords/chevys)
when filter is mounted to da block like this: U
not when filter is mounted like this: [
& of course, wet the filter gasket/seal w/ fresh oil before installing to help removal in the future.
Old Jul 23, 2006 | 10:39 AM
Default Re: (standbackimapro)
thanks for the input PRO.
Old Jul 23, 2006 | 04:57 PM
02 accord's Avatar
Default Re: oil filter intallation. (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Myself, I crank them on as hard as I can by hand.</TD></TR></TABLE>
That's what I do. Then, I back it off 1/4 turn.
Old Jul 23, 2006 | 07:09 PM
95accordex1's Avatar
i just do it half a turn after it mates to the block.
Old Jul 23, 2006 | 07:48 PM
Vinceg99's Avatar
Default Re: (95accordex1)
I put it pretty damn hand tight ever filter says something different on the side from 1/2 turn to a turn after it touches.
Also by no means am I trying to be a dick BUT if you have never done this before have someone that has give you a hand the last thing you want is to seize your motor cause of an oil change you performed....
Old Jul 24, 2006 | 10:00 AM
Heat's Avatar
Default Re: (Vinceg99)
I also tighten the oil filter on my Accord (and my commuter, a Volvo) by hand as hard as I reasonably can. Have never had a leak and can always take them off reasonably easy by hand the next time. And this was the one nice thing about Fram filters - the rubber grip on the end made them easy to put on and take off. I use Honda filters now.
And as mentioned above, be sure you put some oil on the gasket (the rubber part) of the new filter before you put it on. Just touch some old oil (or new oil if you want) with your finger tip and run it around the gasket.
Old Jul 25, 2006 | 12:22 AM
yo, vince
Don't say that ****! (i'll freeze my motor) now you got me paranoid!!!. Anyway i did the oil change fairly easy like everyone here said lube the gasket which i did and hand tighten the filter which i did and gave an the filter extra tightening with the filter wrench. Then ran the car to check for leaks. I HOPe to god my motor DON'T FREEZE. i'll keep ya'll posted
Old Jul 25, 2006 | 10:50 AM
snyderman5's Avatar
Default Re: (Jmumblez2001)
you'll be fine don't worry
Old Jul 25, 2006 | 04:50 PM
BLKFLSH's Avatar
Should not be a problem. Make sure to put a little oil on the new filter gasket. It makes it a little easier to seal. Don't over do the filter wrench tightening. That can make them a pain to remove. You will learn that hand tight, is tight enough. Happy Hondaing
Old Jul 25, 2006 | 11:41 PM
Default Re: (BLKFLSH)
hey is it normal to remove the old oil filter by hand, which i did when doing the oil change recently.
Old Jul 26, 2006 | 02:32 AM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 &raquo;</TD></TR><TR><TD CLASS="quote">hey is it normal to remove the old oil filter by hand, which i did when doing the oil change recently.</TD></TR></TABLE>
sometimes you can, sometimes you cant, depends on how tight the filter was put on.
you only want the filter tight enough to where it wont back off, it has a seal so it wont leak, no need to overly tighten them.
i tighten them down as hard as i can with my left hand (im right handed and my left is my weaker arm)
devin_hoang
36
Mar 24, 2009 01:08 PM
Noch
Jul 26, 2008 01:47 PM
EKB18BPR3
11
Aug 18, 2002 11:53 PM
yellowbuffalo
Mar 16, 2002 05:54 PM
Type Goch
Jul 1, 2001 10:11 AM
