b16 Tranny.....Axle Popping Out
Old Jul 22, 2006 | 02:54 PM
T_bones's Avatar
Default b16 Tranny.....Axle Popping Out
I have recently replace a axle on passenger side... Axle has popped out on my 3times so far. I have taking a block and beat it back into the tranny.... Axle sits flush against tranny.... but after awhile it just pops back out & leaking transmission fluid.I have replaced transmission mount & driver side mount & lower torque mount.
My question is if I have a bad axle seal on the drivers side would this cause the axle to be popping out all the time? Thanks in advance.
Old Jul 23, 2006 | 06:58 AM
T_bones's Avatar
Default Re: b16 Tranny.....Axle Popping Out (TEGhasJDMfever)
bump
Old Jul 23, 2006 | 07:27 AM
mmuller's Avatar
Mad Scientist
no, a bad seal would not cause your axle to pop out, i would start by changing the circlip .
Is the axle the correct lenght?
Old Jul 23, 2006 | 06:02 PM
RPRacing's Avatar
you have the wrong axle.
Old Jul 23, 2006 | 07:06 PM
radteg's Avatar
this happened to me... but with mine the teeth on the end was grinded down and it slid out...don't hit it back in there u have to line the axle with the hole and push it in with force but not hitting it with something thats how u can bend and break things. get a new clip that goes at the end of the axle and if it is not on the end then it might be inside of the tranny(bad) a new clip is like a buck i think i can't remember but it's nothing and if all else fails take the axle back and have them give u a new one.
FreshxJDM
Honda CR-V & Element
Aug 14, 2013 07:21 AM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
aziaticvang
Dec 27, 2007 05:22 PM
powerdbygarrett
Jul 25, 2007 07:48 PM
92sleepR
Mar 21, 2003 12:40 PM
